3-Point To Sleeve Hitch Adaptor
39 replies to this topic
#1 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted August 17, 2014 - 03:23 PM
I am wanting to start this, but work and weather is killing me. Right now it is 97° with NO wind. Just too hot to warm metal to bend it. Can't seem to get time early morning to start on this.
#2 MH81 OFFLINE
  • 29,978 Thanks
Posted August 17, 2014 - 04:09 PM
Do you have a vision or a drawing?
Is it like the Sears style only heavier?
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,049 Thanks
  • 2,900 posts
Posted August 17, 2014 - 04:36 PM
Ditto^
#4 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted August 17, 2014 - 06:12 PM
Here's a drawing of the uprights. The cross piece will be 3"X2"X1/4" angle.
I will use 3/8" X 2" strap for this. Should be heavy enough!
  • MH81, Alc, Texas Deere and Horse and 1 other said thanks
#5 KennyP ONLINE
  • 40,890 Thanks
  • 47,094 posts
Posted August 19, 2014 - 05:27 AM
I reworked the drawing a bit and included the cross piece. Took out all the dimensions, but they are basically the same.
  • DH1, MH81, Alc and 1 other said thanks
#6 MH81 OFFLINE
  • 29,978 Thanks
Posted August 19, 2014 - 06:33 AM
Looks great Kenny.
Don't think you'll bend it with any GT.
#7 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted August 19, 2014 - 06:38 AM
looks good
#8 FrozenInTime OFFLINE
FrozenInTime
  • 658 Thanks
  • 404 posts
Posted August 19, 2014 - 12:07 PM
I don't have the skills to build one some I'm planning this winter to purchase https://heavyhitch.c...itcase-weights/  .  They also sell the adapter for the sleeve hitch to go with it.  https://heavyhitch.c.../3-point-hitch/
  • TomLGT195 said thank you
#9 TomLGT195 OFFLINE
TomLGT195
  • 4,049 Thanks
  • 2,900 posts
Posted August 19, 2014 - 05:39 PM
the 2 holes, to left and right of pin location, are they for nut/ bolt tightening device? to take sway out of attachment?
#10 KC9KAS OFFLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted August 19, 2014 - 06:59 PM
Yes, that is what they are.
These are Allen heads, and most are bolts with a lock jam nut to hold it in place.
  • KennyP and TomLGT195 have said thanks
#11 KennyP OFFLINE
  • 40,890 Thanks
  • 47,094 posts
Posted August 19, 2014 - 07:03 PM
Yepper! Gotta have that for a sleeve hitch! I'll use 1/2" bolts. Just didn't add that detail in.
#12 OldBuzzard ONLINE
OldBuzzard
  • 7,097 Thanks
  • 4,816 posts
Posted August 19, 2014 - 08:48 PM
There is a plate that pins on the hitch along with the implement that those bolts put pressure on to keep the implement from swinging.
You don't use it for every implement though.  For instance you don't use it with the moldboard plow as it needs to be able to swing a bit.
#13 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted August 20, 2014 - 09:58 AM
Kenny , I would try and move the mounting point for the sleeve attachment as close to the tractor as I could to give you better weight distribution and less "rudder" control from the implement. :thumbs:
  • MH81, KennyP and TomLGT195 have said thanks
#14 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted August 20, 2014 - 10:33 AM
 Kenny where were those specs when I was building mine..????  LOL
Looks good..!!!
#15 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,370 posts
Posted August 20, 2014 - 04:24 PM
Just a FYI. Bush Hog sold a sleeve hitch piece to allow the 3pt A-frame to be used as a sleeve hitch as well. My good friend Jack happened to have one that he allowed me to add to my collection,image.jpg image.jpg
