1450 Super Chief Steering Wheel
8 replies to this topic
#1 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted August 17, 2014 - 11:15 AM
Is there any tricks to removing the steering wheel? I can't get it off and I don't want to break it. Thanks for any help.
#2 KC9KAS ONLINE
KC9KAS
  • 5,326 Thanks
  • 4,672 posts
Posted August 17, 2014 - 12:39 PM
Don't know your particular machine, but make sure any roll pin(s) are removed. Use a small punch (smaller diameter than pin) to remove the roll pin.
Use lots of penetrating oil, drink a beer, then use more penetrating oil. Do this for a couple of hours then go to bed.
When you feel better (hopefully the penetrant has helped) and try again to remove the wheel.
If you don't drink, that is ok. The point is, USE PLENTY OF PENETRATION OIL AND LET IT SIT!
You may need a puller something like this:
  • NyRedNeck said thank you
#3 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted August 17, 2014 - 06:37 PM
I have tried pulling on it and I am using penetration oil but it will not budge
#4 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted August 17, 2014 - 06:43 PM
I just went out and looked mine over. I don't think there is enough room for a bearing puller like the silver one in the above post. May have to improvise something under the wheel to pull on.
#5 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted August 17, 2014 - 09:51 PM
Yeah I have the one in the picture and I could not make it work.. I'll maybe just have to rig something up
#6 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted August 18, 2014 - 05:28 AM
The wheel has a bit of a lip on the bottom. You may need some sort of spacer under there to push up with. Good luck with it. If you get something rigged, put some tension on it and snug it a little each day. You may come home from work and find it ready to pull.
#7 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted August 19, 2014 - 02:59 AM
You might need to loosen up things enough to get the bottom clamping halves to fit by the dash, but the tool above is definitely the one to use. Had the same issue with one I was working on as well.
#8 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted August 24, 2014 - 03:12 PM
Thanks for the help I should be able to figure something out
#9 KennyP ONLINE
  • 37,456 Thanks
  • 45,480 posts
Posted August 24, 2014 - 04:50 PM
I hope you get it off without breaking it!
