New Cub Cadet
17 replies to this topic
#1 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted August 17, 2014 - 06:47 AM
Liked the look of the Cub 1641,  been out-of-doors for a long time but, looks nice.
I did find at (MTD (ugh!)) an owners manual.
Doesn't run, but engine turns by hand. No battery and wiring looks awful. No key switch, fell out wherever. 16hp Briggs twin cylinder, horizontal naturally.
Deck is a 48" GT 317190. Is there a manual for the deck, mounting and dismounting?
Deck has usual rust. Cleaning and paint will fix that.
Is there a way to hot wire the engine, just to run it?
Any help, greatly appreciated.  :thank_you:
  • bgkid2966 said thank you
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,210 posts
Posted August 17, 2014 - 07:48 AM
That's going to look really funny on your 'horse play' list.
#3 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted August 17, 2014 - 08:20 AM
Don't I know it! Grandsons "needed" the Cubbie project.  :bounce:
#4 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted August 17, 2014 - 05:21 PM
The CC 1641 doesn't have an ignition switch and the wires that would attached (lots of colors) are hangin' 'round.
Does anyone know where I can pickup a wiring diagram?
I did manage just to jump the starter to turn the engine over, oil looked fine and the engine needed a bit of lube flow.
#5 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted August 20, 2014 - 04:07 PM
You can get wire diagrams off of google
#6 KennyP ONLINE
  • 40,984 Thanks
  • 47,148 posts
Posted August 21, 2014 - 06:06 AM
I'm not sure about this, but here is a wiring diagram for a 1650. May be close.
  • Tankman said thank you
#7 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted August 23, 2014 - 06:23 AM
Thanks for the wiring diagram, need all I can find.
I did order an ignition / key switch from partstree.com; delivery 08/25. From there, movin' ahead.
Curious? Guessing this is a lawn tractor but, seems quite "beefy", heavy duty. Is the 1641 a wide frame, seems so?
Started looking, prematurely perhaps, for a snow blade and mount. Find listing for both wide and narrow frames (?).
The black plastic part that plugs onto the ignition switch was broken and 'lectric burned. Burn / melt was only on the black wire connection. Any clues?
Another free hangin' wire connection fit the switch on the shift lever. Does the switch, which I reconnected, only turn on lights?
Grandsons lookin' forward to barn (shop) time but would rather be ridin'!   :dancingbanana:
Saturday, today, loadin' the kids in the pick 'em up headin' to TSC!
Edited by Tankman, August 23, 2014 - 06:25 AM.
#8 KennyP ONLINE
  • 40,984 Thanks
  • 47,148 posts
Posted August 23, 2014 - 07:11 AM
Glad you found a correct wiring diagram. That Black wire at the ignition is the battery wire feeding it. The connector was probably a bit loose fitting, causing it ti heat and melt things. I'm not sure what that other switch could be without seeing a pic of a dash setup on these.
#9 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted August 23, 2014 - 08:12 AM
Rainin' outdoors, grandsons going to clean and paint (high temp black) the engine baffles.
Surprisingly, or not, lots of debris.
Is the 1641 a "garden" or "lawn" tractor? Seems beefy for a "lawn" tractor. I do associate MTD with "lawn."
When the Cub had 'lectic problems, the old timer parked the Cadet. He passed away, Cub outdoors for a year before his son sold it to me. "As is" naturally. Now the boys, grandsons and pop-pop have a project.   :bounce:
We all needed it too!
#10 Guest_rdehli_*
Guest_rdehli_*
  • Guests
Posted September 11, 2014 - 06:48 AM
your 1641 is considered a wide frame. if your looking for a front mount blade, get one with the 82 series or newer lift assembly, otherwise when you raise the blade it will hit the front tires.
you will like the 1641 it has nice styling , nice ride too.
#11 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted September 11, 2014 - 07:54 PM
Never thought of it? I'll need a new "_____ Play" list.
Definitely like the looks and the assembly of this tractor.
My 1st tractor was a '32 Farmall. Forget the model but rear tires were five feet in diameter more or less. Had a crank start. Ran real nice. Was only used by me for parades at Rough 'n Tumble in Kinzers, PA.
I donated the tractor to a boys club to work their one acre "farm".  :thumbs:
In '71 I bought a new IH. That was a real machine. Forget the model but thinkin' Low Boy.
#12 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted September 16, 2014 - 04:05 AM
Mounting a new starter on the engine block. Anyone know what size the two mounting bolts are?
Original starter was removed, purchased a new one, now I need to pickup two bolts to get workin'.
The million dollar question? What size are the two mounting bolts?
Engine manual is of no help. Briggs online for support, nada.  :wallbanging:
#13 KennyP OFFLINE
  • 40,984 Thanks
  • 47,148 posts
Posted September 16, 2014 - 04:50 AM
I'll look on my engines to see what they have. Have to wait for daylight, though.
#14 Tankman ONLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted September 18, 2014 - 02:03 PM
The bolts were / are metric, M8-1.25. To make mounting easier, I used socket head bolts w/ lock washers.
The thread length is 'bout 3/4".
Edited by Tankman, September 18, 2014 - 02:04 PM.
#15 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted September 21, 2014 - 07:29 PM
The grandsons love this Cub Cadet 1641.
This is the first ride, I had the youngster pulling a roller on my gravel driveway.
Nice machine!
