Posted August 17, 2014 - 06:52 AM
The main nozzle should've had a slot across the bottom for a large flat blade screwdriver. From your pic, it looks like your either doesn't have it or it' been boogered up by previous removal.
What motor is it off of?
Posted August 17, 2014 - 07:33 AM
Boy, somebody really did a number on that dude.
Tahoe is right. The nozzle should be slotted and it should come out very easy.
That might be a machinist's job to get it out. If the brass is stuck in place hard enough to break off the nozzle, wow...
Ben W.
Posted August 17, 2014 - 07:46 AM
Replacement used Walbro LME, depending on were you live.
(413)-552-8802, ask for Steve, give him the numbers stamped on the side of the carb.
Best of luck.
Jesse
Posted August 17, 2014 - 01:51 PM
Posted August 17, 2014 - 07:42 PM
the carb on my ss12 the throttle shaft is really loose was hoping to use body of this one because they are tight
Posted August 17, 2014 - 07:49 PM
I thought the LME carbs have the replaceable throttle bushing ? if not you might buy one, drill it to size and press it in.
Posted August 18, 2014 - 08:56 AM
They are.
I have been sending mine Walbro carbs to Mark at www.carbrescue.com
The guy does amazing stuff, he can repair or make about any part needed for these carbs. Pretty reasonable in price too.
Posted August 19, 2014 - 05:49 PM
They are.
Thanks, i though so, i'll link his email and fire into the networks.
Posted August 19, 2014 - 08:45 PM
