B&s Model N With Dual Magnetos?
4 replies to this topic
#1 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted August 16, 2014 - 09:23 AM
I was browsing through some old B&S parts manuals and see that there was a B&S model N engine made having dual magnetos.
It uses the same #29617 armature, #29667 points, and #29861 condenser as the common model N, but uses two of each.
Is anyone familiar with these dual magneto engines, or can provide a reason for them?
Longer spark duration?  ....Redundancy? ....Reliability?  ....Military application?
Thanks!
#2 DougT OFFLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted August 16, 2014 - 05:27 PM
I've never seen one. Was the flywheel special? Did it use 2 plugs? I know there was a lighting circuit in the doodlebug engines but never heard of this.
#3 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted August 16, 2014 - 06:58 PM
Doug:
1 Plug, ...Same cylinder head,  ...Same flywheel, ....But 2 plug wires.
It appears the dual ignition (Magneto Assy # 290905)  set-up was only used on Type # 205756.
#4 DougT OFFLINE
DougT
    Dog Approved
  • 6,855 Thanks
  • 4,953 posts
Posted August 16, 2014 - 07:18 PM
Interesting! I'll have to see if I can come up with a picture of it. Would it be something that would change the timing? It seems that you couldn't fire the coils at the same time with the same flywheel.
#5 Bruce Dorsi OFFLINE
Bruce Dorsi
  • 3,914 Thanks
  • 2,451 posts
Posted August 16, 2014 - 07:32 PM
One coil is mounted in the usual position.  ....The other coil is mounted at approximately the 3 o'clock position.
The coils would not fire at the same time, but sequentially.   ....The "usual" coil would fire first, then the other coil would fire after approx 90* of crank rotation.
I'd love to know the reason and application for this engine!
