Trac Vac Rolled Over
trac vac rolled over
14 replies to this topic
#1 Trac Vac Gal OFFLINE
Trac Vac Gal
  • 1 Thanks
  • 2 posts
Posted August 15, 2014 - 10:09 PM
I was mowing with the Trac Vac in tow but no hose.  The Trac Vac was not in operation at the time.  I made a sharp turn on a slope and the Trac Vac rolled over onto its side.  I was able to disconnect it from the mower.  My problem now is how to stand the Trac Vac upright again.  Any suggestions?
#2 TomLGT195 OFFLINE
TomLGT195
  • 4,055 Thanks
  • 2,903 posts
Posted August 16, 2014 - 06:06 AM
I presume it's too heavy to do by yourself. Any trees around to use a come -along? Lift with a lever and blocks? How bout using tractor to pull over? Hope this helps. Tom
Pics would be helpful to see the situation.
Edited by TomLGT195, August 16, 2014 - 06:08 AM.
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,055 Thanks
  • 2,903 posts
Posted August 16, 2014 - 06:08 AM
Welcome to GT Talk!
Hang around this site has plenty helpful people and info.
#4 MH81 OFFLINE
  • 29,979 Thanks
Posted August 16, 2014 - 06:12 AM
I guess we should start with :welcometogttalk:
Next, what size trac vac is it? They have made several sizes from what I understand. Is it possible to throw u a pic of the situation so we can see the potential issues?
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted August 16, 2014 - 06:30 AM
:ditto:
#6 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 16, 2014 - 06:34 AM
:welcometogttalk: :wewantpics:
#7 panzersarebest OFFLINE
panzersarebest
  • 523 Thanks
  • 407 posts
Posted August 16, 2014 - 06:39 AM
Welcome to Gttalk!
#8 boyscout862 OFFLINE
  • 13,557 Thanks
  • 9,431 posts
Posted August 16, 2014 - 06:49 AM
Welcome to GTT. The big question is how to stand it back up without damaging it or you getting hurt. You need to post several pictures that show the specific situation. I would try to just right it by hand if it doesn't weigh too much and the slope isn't too steep. If that can't work, I'd unload it to make it lighter. May even disassemble it enough to right it by hand. Good Luck, Rick
  • Bill56 said thank you
#9 plowboy OFFLINE
plowboy
    TRACTOROLOGIST
  • 133 Thanks
  • 229 posts
Posted August 16, 2014 - 07:12 AM
I have the Agri-Fab version, pretty much the same thing only bigger.  I'm guessing it's full or in a bad spot because it doesn't take much to flip it back up.  One guy can do mine.  I would deff be looking at a come-a-long with a rope tied to a tree, the tractor, the back of a truck, anything would help.
This is what mine looks like....is yours similar?
#10 richwoodrocket OFFLINE
richwoodrocket
    16 year old JD lover
  • 147 Thanks
  • 177 posts
Posted August 16, 2014 - 07:30 AM
Welcome to the forum. Pictures would help.
Got anything with a loader? :)
#11 UncleWillie OFFLINE
  • 16,262 Thanks
  • 8,976 posts
Posted August 16, 2014 - 10:51 AM
If it is full can you empty it out?
If not see about getting a strap on the high side and pulling it back over with the tractor.
#12 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,142 posts
Posted August 16, 2014 - 12:17 PM
Call a few neighbors and tip it back over.
#13 HANKG OFFLINE
HANKG
  • 6,597 Thanks
  • 3,530 posts
Posted August 16, 2014 - 01:06 PM
Welcome aboard enjoy !
#14 Trac Vac Gal OFFLINE
Trac Vac Gal
  • 1 Thanks
  • 2 posts
Posted August 16, 2014 - 08:02 PM
Success. Tonight I was able to stand it up using the bucket of the tractor, inching forward and lifting at the same time. The box was empty. I positioned the bucket on the corner closer to the engine, because that's where the weight was. The Trac Vac moved backwards as the wheels made contact with the ground, but I was able to follow it while raising the bucket. Thanks to all for your advice.
#15 boyscout862 OFFLINE
  • 13,557 Thanks
  • 9,431 posts
Posted August 17, 2014 - 08:34 AM
Glad that you were able to take care of it. Good Luck, Rick
