Afternoon,
Anybody here using John Deere Corn Head grease in their old gear boxes etc ? I use to work on a Mueller tapping machine which used a heavy duty type speedo cable to power the head and it was lubed by a special 00 grease. I was told that,s where oil meets grease,it would flow on it,s own but mostly stayed in place. Oil is thickened by adding soaps and such but this Corn Head grease might be ideal for those older worn gear boxes prone to leaking. Some things like a Duro pump running in oil never had a seal just used a wide plain bearing to keep the lube in. I would be interested in hearing about your experiences. Cheers Mike
