Hydro Fan Removal
5 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 15, 2014 - 02:28 PM
Does anyone know how to get the hydro fan off the u joint on a 990?
#2 Sawdust ONLINE
Sawdust
  • 5,650 Thanks
  • 3,366 posts
Posted August 15, 2014 - 08:22 PM
I had the same problem on mine. I soaked the shaft & yoke area with WD40, applied a little heat.  I placed a ball joint remover tool between the shaft & pump housing. I tapped on this lightly & it came loose. Since my fan was already split I cut it off to get it out of my way. I will be replacing the fan with a new one.
Page 105 of my Thread     http://gardentractor...-mtd-990/page-7
  • BairleaFarm said thank you
#3 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 16, 2014 - 12:11 PM
So does the u joint just sit on the hydro shop with no roll pin?
#4 Sawdust ONLINE
Sawdust
  • 5,650 Thanks
  • 3,366 posts
Posted August 16, 2014 - 02:31 PM
Mine never had any just a key way & slid off. The other end to the engine had a roll pin.
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 16, 2014 - 04:45 PM
Ok thanks. I didn't want to start yanking just to find out there was something holding it on.
#6 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted August 16, 2014 - 04:59 PM
Ideally the drive shaft u-joint is suppose to slide a little on the pump shaft, should there be flexing between the engine and transmission. Much like a car drive shaft. Over time the u-joint rusts and freezes to the pump shaft. The exploded parts view shows the key under the u-joint end.
I put grease or anti-seize on the shaft when reassembling.
Edited by VTXrider, August 16, 2014 - 05:00 PM.
  • BairleaFarm and Sawdust have said thanks
