Wanted
Looking For A Ball Button Hitch
xuv550 john deere
8 replies to this topic
#1 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,262 posts
Posted August 15, 2014 - 02:04 PM
Hi guys,
I'm looking for a "Kugelkopf-Anhängekupplung" and translated it as a ball button hitch and I don't know, if it's right.
It looks like this 2''Kugelkopf.jpg . This picture is from the XUV 550 OM, but I didn't find the part in JDPC. Important is the 2'' square tube to mount te drawbar to the Gator.
Is this part sold in the USA and where can I buy it?
#2 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted August 15, 2014 - 02:09 PM
http://www.tractorsu...-kits-2-in-drop
check here
I can not get it to come up ,tractorsupply.com.the website will not load for me
Edited by drbish, August 15, 2014 - 02:12 PM.
  • jd.rasentrac said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,262 posts
Posted August 15, 2014 - 02:12 PM
wow, this was really fast! thank you, drbish!
Edit: yep, this will be the right part! Now I'll see, where I can purchase it.
Edited by jd.rasentrac, August 15, 2014 - 02:25 PM.
#4 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted August 15, 2014 - 02:13 PM
http://www.ebay.com/...=item41838dda3e
#5 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted August 15, 2014 - 04:28 PM
Something like this?
http://www.harborfre...iver-69673.html
#6 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted August 15, 2014 - 04:30 PM
I don't know if Walmart stores have made it to Germany yet, but they sell these in most of their stores.
Are these pieces not common in Germany for towing boat trailers, camping trailers, utility trailers, etc. ??
Be advised that the hitch ball is available in 1-7/8" (47.625mm), 2" (50.8mm), and 2-5/16" (63.80mm) diameters.  ....The threaded stem of the ball is also available in different sizes, so the hole in the hitch has to match the threaded stem of the ball.
  • boyscout862 and jd.rasentrac have said thanks
#7 boyscout862 ONLINE
  • 12,844 Thanks
  • 9,169 posts
Posted August 15, 2014 - 08:53 PM
I usually pickup those hitches for $5 to $10 depending on drop at swap meets. They are easy enough to make with a piece of 2" square tubing. Drill a hole for the ball and another for the hitch pin. Show us what you are up to. Good Luck, Rick
BTW they are sometimes called shin destroyers if you leave them sticking out the back of your truck. This is the voice of painfull experience.
  • Alc and jd.rasentrac have said thanks
#8 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,262 posts
Posted August 16, 2014 - 04:35 AM
Thank you, but this part is mounted at the gator. Now I know where I can find this thing, too.
#9 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,771 Thanks
  • 4,262 posts
Posted August 16, 2014 - 04:45 AM
Hi Bruce, I live in Germany! And here you infringe some rules every day. For every thing you'll use, you'll need a certificate of nonobjection, And most of the police officers really don't know what's allowed and what's not allowed.
And then there are the european instruction - mostly different to german law...
Yep guys, it's not easy to live here  :D
But know my JD dealer found this ball hitch - naturally not allowed to use in D - in Bruchsal and I ordered one!
Thanks again to all of you for your help!!!
Edited by jd.rasentrac, August 16, 2014 - 04:46 AM.
Also tagged with one or more of these keywords: wanted, xuv550, john deere
