Wiring game !
7 replies to this topic
#1 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 07, 2011 - 05:05 PM
Lets play a game called Help Edge Wire this mess
Can you be the one to draw wires to this diagram in the correct working manner
[attachment=7624:8366.attach]
RULES
you must use different colered or numbered wire
you must make good easy to read contacts
your allowed to poke fun at artistically challenged members
you cannot wire diagram to short out
your allowed to rearrange any part to help veiw diagram better
1st one that gets it working correctly wins
PRIZES
1st The title of winner:rocker2:
2nd A good nights sleep knowing you came in 2nd:thumbs:
3rd An all nights stay at the wonderful YOUR HOUSE :laughingteeth:
4th Well, you came in fourth :(
seriously guys i need some help & also with this wiring thing to!!
#2 grand OFFLINE
grand
  • 1,987 Thanks
  • 1,996 posts
Posted February 07, 2011 - 08:14 PM
I know some of the members here have enough knowledge to solve your wiring problem. Unfortunately that doesn't include me. I am looking forward to the solution. Good luck.
What is this going to run ?
#3 MH81 OFFLINE
Posted February 07, 2011 - 09:46 PM
Google Image search.
Posted ImagePosted ImagePosted ImagePosted Image
  • Merle013 said thank you
#4 Alc OFFLINE
  • 6,741 Thanks
  • 7,395 posts
Posted February 07, 2011 - 10:06 PM
I might be way off base on this but could the ignition switch shown be for a magneto ignition ? Don't they ground the ignition wire when turned off ?
#5 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,238 Thanks
  • 5,550 posts
Posted February 07, 2011 - 10:11 PM
What does the M stand for on your key switch?
If M is Magneto then either you have the wrong key switch, or you have the wrong coil shown.
You show a key switch for magneto ignition and a battery powered ignition coil.
I could be wrong here and if so please tell me.
#6 WQDL753 OFFLINE
WQDL753
    Bolensholic
  • 59 Thanks
  • 301 posts
Posted February 08, 2011 - 03:32 AM
Not enugh info for me to go on, but I'd tend to agree that the M on the key is to ground a magneto, and it's been retrofitted. First question is what's it for, next would be find out what has continuity for each key position on your switch. An ohm meter or a test light will work, but we need to know what goes where in all three key positions. I recon my last question is if that's a starter/generator shown than it should have more than one con. on it.
Sorry that's all I got...What was the participation prize again....
#7 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted February 08, 2011 - 08:20 AM
You guy are right.
Wrong ignition switch for a point ignition system.
The "M" terminal is used to short the trigger signal to ground to kill the spark.
Will require an ignition switch with an "I" terminal.
#8 M&M13 OFFLINE
M&M13
  • 11 Thanks
  • 159 posts
Posted February 08, 2011 - 11:02 AM
Yes you guys are correct it has all these components on one tractor it has rectifier & not regulator also it has stator instead of starter/generator it is a 10hp Kohler with stator,coil,points,condenser,solenoid & starter ! It may not be possible with this type of key switch but that is the only optional component i can change out right now ! If you have another key switch in mind that would work please feel free to substitute it ! I have many others i could try[attachment=7634:8374.attach]here this might help more
Edited by APPALACHIAN EDGE, February 08, 2011 - 11:26 AM.
