Jd 54C Belly Mounted Grader Blade Parts
1 reply to this topic
#1 GTTinkerer OFFLINE
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted August 15, 2014 - 07:38 AM
I picked up a John Deere 54C belly blade a couple of months ago and finally got around to look at mounting it on a 140H3 and found out I am missing a few parts.
The parts needed are:
Lever item #13 part # M45214
Pin item #21 part # M45216
Pin item #23 part # M45215
Bracket rh item #28part # AM33246
Bracket lh item #28 part # AM33247
Arm item #31 part # M45241
Since all of the parts appear to be easily fabricated I am looking for either the part or the dimensions of the parts.
Edited by GTTinkerer, August 15, 2014 - 07:48 AM.
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 15, 2014 - 07:47 PM
I thought I might be able to get some of the dimensions for the pins from JDParts. If you have an account you can get parts descriptions by clicking on the part no. in the shopping cart. However the pins are NLA so they won't show up in the cart. You might try doing a search for 54C on the net. I remember seeing pictures of a blade installed on a tractor which would give you a pretty good idea for the size of the parts.
