110 Wiring
14 replies to this topic
#1 floydster OFFLINE
floydster
  • 1 Thanks
  • 6 posts
Posted August 13, 2014 - 08:01 PM
Hi all, new to the forum.
I have a 1967 John Deere 110, ser. no. 075273M. round fender.
I am in need of a wiring schematic for this tractor.
Any help sure would be apprciated.
Thanks, Floyd
#2 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 13, 2014 - 08:24 PM
Are you looking to wire it yourself? You can buy a new wiring harness for it from Deere for around $27.00. Just letting you know, as it would be more easier for you. I'll look through my receipts, and see if I can find the part number for you if you want.
Oh, and Welcome to the site. Glad to have another John Deere fan on board!  :thumbs:
Edited by johndeereelfman, August 13, 2014 - 08:25 PM.
  • Trav1s said thank you
#3 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted August 13, 2014 - 08:45 PM
Beat me to the punch.  You might consider replacing the key switch while you are at it.
Welcome!
#4 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted August 14, 2014 - 04:08 AM
:welcome:
#5 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted August 14, 2014 - 08:11 AM
The wiring harness part number is AM30363 and is priced at $27.28 each + tax.
This harness is used for 1965-1967 110's and the '66-'67 112's.
The '63 and '64 110's take a different harness, and is no longer available from Deere.
#6 floydster OFFLINE
floydster
  • 1 Thanks
  • 6 posts
Posted August 14, 2014 - 09:02 AM
Guys thanks for the welcome and info.
A little history, I have had this 110 for a long time, I re-stored it 10 years ago and have used it regular since then.
It quit charging last week so I rebuilt the S/G and replaced the voltage reg., after reassembly it turned over very good however
I wasn't getting power to the coil. I had a schmatic for this tractor, but in my papers I can't find it:(
I did re-wire the complete tractor when I re-built it. I just wanted to refresh myself on the wiring, thus the complete schematic I need.
I am just getting started on figuring out the prob.
I have been working on garden tractors for a long time, restored two Bolens,( great tractors) a JD 420, Simlicity Prestige and several others which I still have and use:)
Thanks again guys, good to be here:)
Floydster
#7 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted August 14, 2014 - 09:31 AM
I have a harness diagram at home, I will snap a pic and post it up for you since you want to repair the harness you have.
#8 floydster OFFLINE
floydster
  • 1 Thanks
  • 6 posts
Posted August 14, 2014 - 10:06 AM
Trav, thanks so much for your info, very much appreciated.
Floydster
#9 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted August 17, 2014 - 01:27 PM
Better late than never
#10 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted August 19, 2014 - 09:17 AM
How goes the project?  :watch_over_fence:
#11 floydster OFFLINE
floydster
  • 1 Thanks
  • 6 posts
Posted August 19, 2014 - 04:31 PM
Trav, I have that schematic, thanks.
I put new brush's in the S/G, put it all back together, started right up, charged great,
started it 4-5 times all was good. Wiring is all tight and correct.
Put all my tools away, took it for a spin, charge light came on--don't know were my next move is.
Not charging at all, reads 12.25v. Wouldn't be so bad if the S/G and V/R wasn't in such a hellish place.
Any input would be appreciated, this is a hair puller:)
Thanks, Floyd
#12 Trav1s ONLINE
Trav1s
  • 3,580 Thanks
  • 4,557 posts
Posted August 19, 2014 - 05:01 PM
That was my big gripe about the RF 110 owned - getting to that stuff was a real pain.
As for what to do next, I would begin with the following things:
  • Make sure you have good metal contact on the solenoid and all ground points (you might consider those star washers)
  • Clean battery terminals and cable
  • Make sure the belt is tight on the starter/generator
#13 floydster OFFLINE
floydster
  • 1 Thanks
  • 6 posts
Posted August 20, 2014 - 08:29 AM
Thanks Trav, will let you and the forum know when I find the prob.
May take awhile:(
Thanks again, Floydster
#14 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 20, 2014 - 08:40 AM
:welcometogttalk: :wewantpics:
#15 floydster OFFLINE
floydster
  • 1 Thanks
  • 6 posts
Posted August 26, 2014 - 10:39 AM
Well, I took a screw driver and tapped on the V/R while the tractor was running, it started charging right away, that was five days ago and it has  been running great ever since---go figure.
Stuck points on regulator??
Appreciate any input:)
Thanks, Floyd
