Shining Up My Plastic Gas Tank
11 replies to this topic
#1 Sawdust ONLINE
Sawdust
  • 5,039 Thanks
  • 3,095 posts
Posted August 13, 2014 - 07:07 PM
I didn't want to paint my gas tank on my MTD 990 because I believe it would eventually come off. It had discolored to a point of looking gray. I remember how rubbing some plastics with transmission fluid would give them an Armour All effect. I scrubbed it with soap & hot water & air hosed it dry.  I gave it a couple of coats & rubbed it all in once a day for a few days & wiped the excess off. Here are the before & after three weeks later.
  • MH81, Alc, hamman and 8 others have said thanks
#2 classic OFFLINE
classic
  • 4,472 Thanks
  • 1,990 posts
Posted August 13, 2014 - 07:49 PM
Good choice on going with the trans fluid, the tank looks great! It's worth putting some elbow grease into these old machines.
  • hamman, Sawdust and propane1 have said thanks
#3 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted August 13, 2014 - 08:03 PM
That looks really nice. Thanks for sharing the tip!
#4 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 11,426 Thanks
  • 8,683 posts
Posted August 13, 2014 - 08:07 PM
Will the trans fluid collect dirt?
  • hamman and Sawdust have said thanks
#5 propane1 ONLINE
propane1
  • 7,387 Thanks
  • 3,659 posts
Posted August 13, 2014 - 08:08 PM
Nice. I guess it would work on most plastics. My fender flares on my ranger are getting discoloured and turning white. I will have to try that on them. Noel
#6 Sawdust ONLINE
Sawdust
  • 5,039 Thanks
  • 3,095 posts
Posted August 13, 2014 - 08:43 PM
Probably no more than anything else on a GT. Once it soaked I rubbed what was on the surface off.
  • hamman, LilysDad and Gabriel have said thanks
#7 glgrumpy OFFLINE
  • 7,732 Thanks
  • 7,353 posts
Posted August 13, 2014 - 08:53 PM
OK.....weird,but OK! :ok: :sleep_sign:
  • hamman said thank you
#8 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted August 13, 2014 - 10:17 PM
Very nice!
#9 JDBrian OFFLINE
  • 9,595 Thanks
Posted August 14, 2014 - 05:43 AM
That looks great. I may use that the next time I need to clean up a tank.  I've used Fusion plastic paint on a tank before and it works well but will come off if you get fuel on it. That's usually only a problem near the filler port on the particular tractor I was working on.
#10 TAHOE ONLINE
TAHOE
  • 7,421 Thanks
  • 5,417 posts
Posted August 14, 2014 - 08:29 AM
I painted a Sears plastic tank with Fusion. Still have not used it yet and I was worried about it peeling, guess I know now.
Looks nice Jim.
Better hurry up and get it done since you got another coming!!!  HAHA
  • JDBrian and Sawdust have said thanks
#11 HDWildBill OFFLINE
  • 8,968 Thanks
Posted August 14, 2014 - 09:00 AM
Looks good.  When I have used products like Armour all they always seem to fade,  will this do the same over time?
  • Sawdust said thank you
#12 Sawdust ONLINE
Sawdust
  • 5,039 Thanks
  • 3,095 posts
Posted August 14, 2014 - 08:45 PM
Armour all always faded for me too.
