4 Hp Briggs Snapper Push Mower
briggs snapper
25 replies to this topic
#1 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 12, 2014 - 05:21 PM
I need some help with a 30 year old Snapper push mower with a 4HP Briggs motor.  It was working fine then it stopped when the owner pushed it up a slight incline under a shrub.  It stalled and would not restart for her.  Owner added new plug, checked the oil, and the usual - all checks out.  I have messed with a bit and this is what I have discovered about it:
  • Spark is good
  • Will not run on carb cleaner thru the carb or plug hole
  • Repeatedly backfires thru the carb
  • If you pour gas into the carb and try to start it the gas will spray out of the carb
Based on all of this I am thinking that the intake valve is sticking open.  Any other thoughts or suggestions before I pull the shroud and head??
#2 Bill 76 ONLINE
Bill 76
  • 1,689 Thanks
  • 1,082 posts
Posted August 12, 2014 - 06:09 PM
Did she hit anything under the scrub that maybe sheared the flywheel key,That could throw it out of time.
Just a thought
Also check for compression that would tell you if the intake is stuck open
Edited by Bill 76, August 12, 2014 - 06:15 PM.
  • trowel and Trav1s have said thanks
#3 trowel OFFLINE
trowel
    Summer.
  • 4,819 Thanks
  • 4,533 posts
Posted August 12, 2014 - 07:26 PM
Just a thought
I was about the type that, sounds like it.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,169 Thanks
  • 5,762 posts
Posted August 13, 2014 - 07:34 AM
I did that and hit a root. Twisted the crankshaft.
#5 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 13, 2014 - 09:02 AM
Ok, I will pull the shroud and check the key.  I am also going to pull the head while it is apart.
#6 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 13, 2014 - 08:54 PM
Pulled the shroud off of the Snapper tonight.  It seems I need a special puller to remove the flywheel on this one.  Any suggestions on how to get this one off short of buying a puller?  My auto gear puller will not work on this one.
#7 LilysDad OFFLINE
LilysDad
    Crazy about GTTalk
  • 10,072 Thanks
  • 7,916 posts
Posted August 14, 2014 - 06:51 AM
Do you have an impact wrench? If you stick a big screw driver through the fins on the flywheel, your almost certain to break off the fins!
#8 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 14, 2014 - 04:27 PM
My hunch was right - the intake valve was stuck open
Edited by Trav1s, August 14, 2014 - 04:30 PM.
#9 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 14, 2014 - 04:32 PM
So the next question is this:  If I get the valve seat to reseat in the block will it stay?
I noticed that the head gasket was leaking around the valve and there was much carbon on the head.  Do I part it/scrap it or play around with it?
#10 LilysDad OFFLINE
LilysDad
    Crazy about GTTalk
  • 10,072 Thanks
  • 7,916 posts
Posted August 14, 2014 - 06:03 PM
If it were me, I might try using a punch and hammer to peen the seat in place. Other than a new head gasket, I wouldn't spend much money on it.
#11 Bill 76 ONLINE
Bill 76
  • 1,689 Thanks
  • 1,082 posts
Posted August 14, 2014 - 06:41 PM
:iagree: Peen it place and have the owner use it for a trade in on a new mower,I don't think it has much time left on earth.
#12 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 14, 2014 - 07:30 PM
Well, I used a punch to tap it into place.  I told her it is beyond help and she is selling the house at the end of the month so she does not need a mower at her new place.  I think I will part it out and salvage what I can. It is a very nice mower and it has electric start.
#13 LilysDad OFFLINE
LilysDad
    Crazy about GTTalk
  • 10,072 Thanks
  • 7,916 posts
Posted August 14, 2014 - 09:15 PM
You should be able to find another B&S engine.
#14 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 15, 2014 - 07:00 AM
The model is 21405ps and I will do some digging for options.
#15 Trav1s ONLINE
Trav1s
    Got points?
  • 2,621 Thanks
  • 3,765 posts
Posted August 15, 2014 - 08:45 AM
Here is another pic of the machine.
  • Bill 76 said thank you
Also tagged with one or more of these keywords: briggs, snapper
