J.d. Garden Tractor Model Selection
11 replies to this topic
#1 porsche924s OFFLINE
porsche924s
  • 3 Thanks
  • 4 posts
Posted August 12, 2014 - 03:49 PM
Good Day:
I am looking for advice on which used  J.D. tractor to buy. My needs are mainly for mowing 1/2 acre of grass and leaf removal, therefore the model will need to have bagging capability. I want a garden tractor from the 80's or 90's, but it needs to be only one step above a lawn tractor. Based upon these requirements any suggestions?
  • A.C.T. said thank you
#2 Trav1s ONLINE
Trav1s
  • 3,579 Thanks
  • 4,557 posts
Posted August 12, 2014 - 05:13 PM
Welcome!  :wave:
There are several questions I have for you before I post a response:
  • Are you handy?  Do you like to do repairs?
  • Do you have a price range?
  • Would you want to use other attachments like a tiller/blade/snowblower?
Travis
  • TomLGT195 said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 4,053 Thanks
  • 2,901 posts
Posted August 12, 2014 - 07:45 PM
Welcome aboard!
I'm not a JD owner but someone with knowledge in this area will be along . Travis has some good ?'s that would help the guys with advice.
Edited by TomLGT195, August 12, 2014 - 07:45 PM.
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted August 12, 2014 - 07:56 PM
What is your budget?
#5 porsche924s OFFLINE
porsche924s
  • 3 Thanks
  • 4 posts
Posted August 12, 2014 - 08:05 PM
Trav1s:
Thank you for the response.
I would not mind doing any repairs or a limited restoration work. My budget is about $1000., but I like bargains. I don't need any attachments other than a cart.
#6 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted August 12, 2014 - 08:13 PM
Do you have any obstructions, gates, or uneven terrain that would limit the width of the mower deck?
  • Trav1s said thank you
#7 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted August 12, 2014 - 08:27 PM
This one is overpriced by about $3-400, but that model is what I would recommend. Still supported by Deere for parts and has the single cylinder Kawasaki that is nearly bulletproof.
http://nh.craigslist...4606020505.html
  • Trav1s, A.C.T. and porsche924s have said thanks
#8 Trav1s ONLINE
Trav1s
  • 3,579 Thanks
  • 4,557 posts
Posted August 12, 2014 - 08:32 PM
Ok, If I were to make a suggestion based on what you have mentioned I would say one of the following:
Gear drives:
  • Late 100 series (especially the '72 to '74 110/112 with 10HP K241/12 HP K301)
  • 210/212  (10 HP K241/12 HP K301)
All of these take a Model 38 (38") or variations on the 46" decks for gear drives.
Hydro machines:
  • 300 / early 316 (16 HP k341)
  • 312/314  (12HP K301/14HP K321)
  • 317 (17HP KT-17 or Series II)
All of those machines use a Model 41 (38") or several variations of a 46" deck
All of these machines are well built and will last if maintained.
I don't know the later machines as well as the '60's to early 90's stuff.
  • porsche924s said thank you
#9 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted August 13, 2014 - 07:49 AM
:welcometogttalk:
#10 porsche924s OFFLINE
porsche924s
  • 3 Thanks
  • 4 posts
Posted August 13, 2014 - 01:00 PM
Cat:
Thanks for the interest, 38-42 inches on the mower is the max. I need given the smaller size of the lawn
#11 Trav1s ONLINE
Trav1s
  • 3,579 Thanks
  • 4,557 posts
Posted August 13, 2014 - 01:31 PM
Cat:
That does make a fair amount of difference as the smaller deck on the 110/112 is rather common and lesson common on the 200 series.  The smaller deck on the 300 series is not common in my experience.
#12 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted August 13, 2014 - 02:49 PM
I always like the JD 160 but it is an older machine built in 1986-88.  12.5 Kawasaki engine, 38" deck, double bagger and it would give you the option of adding a snowblower or push blade at a later date.
I picked up a couple of them over the past few years, tuned them up and gave them to two of the grandsons.
It is a lawn tractor though.
Edited by GTTinkerer, August 13, 2014 - 02:51 PM.
