Head Bolts, 1886-01? -03? -09576?, And Hydraulic Controls.
13 replies to this topic
#1 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 10, 2014 - 11:16 PM
1) On a cast iron Kohler twin (K482) are head bolts the same as any old bolt or are they some special bolt? One of my head bolts has a different size head than the others.
2) How do I Identify which 1886 I have? I understand there are 6 versions, not 9,576 haha but is there some sort of I.D. tag where I can look. I think some models have a Eaton hydro and some have a Sunstrand right?
3) What should the hydraulic controls be labeled on my 1886? Sorry for he noob question, but the decal has faded and I just got this tractor.
#2 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted August 10, 2014 - 11:43 PM
ID tag should be on the top engine tin or the side of the dash.  You could post photos of the tractor from all 4 sides and I could ID it for you....
  • TokyoDrift99 said thank you
#3 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 11, 2014 - 12:34 AM
Haha sorry I took the picture at around midnight, and my phone battery was low so I couldn't use flash. I will get some pics tomorrow.
#4 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted August 11, 2014 - 04:05 AM
Head bolts can be replaced with grade 8 bolts of the same length. Sometimes they can be an odd length which is hard to match from standard length bolts. Before replacing the head make sure the bolts will thread in easily and far enough for the head to seat properly. A bolt that is binding or bottoming out will give a false torque reading and end up causing gasket failure.
#5 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 11, 2014 - 12:04 PM
OK Thanks
#6 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 11, 2014 - 12:24 PM
The hood isn't secured but this should give you an idea.
#7 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted August 11, 2014 - 12:52 PM
Can you post a photo of under the seat I need to know what mount is on it for the seat to 100% ID it.
#8 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 11, 2014 - 01:31 PM
The seat doesn't flip up but I will try.
#9 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 11, 2014 - 01:33 PM
#10 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 11, 2014 - 01:36 PM
Another question.... I discovered the Trans dipstick is busted. Is it OK to try and weld something up using a few bolts and a wing nut? Or should I try and get a new one?
#11 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted August 12, 2014 - 02:04 PM
Looks like a 1886-04.
Let me see if I still have any of the dip sticks I had made up left.
#12 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted August 12, 2014 - 04:07 PM
I'm thinking 1886-04
#13 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted August 12, 2014 - 04:10 PM
Does it have a metal trans dipstick, or the plastic one on the rearend
#14 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted August 13, 2014 - 06:53 PM
It has a plastic dipstick.
If you find one pm me a price. Im still gonna try to make one first.
