I Went To The Ohio Valley Show This Weekend
18 replies to this topic
#1 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 10, 2014 - 11:00 PM
While I was there I saw a tractor there that was restored buy a guy in Hillsboro Ohio his name was Tom. It was an Allis Chalmers 620 it was perfect. I fell in love with this tractor. I wanted to get an ingersoll 4020 until I saw this beast it has it hands down over the ingersoll. I must have a 620 or a 720 allis anyone who has any info on them please share. What is the is the difference between them what's available in attachments. I must know lol I can't sleep for thinking about where to get one to rebuild and restore.
#2 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 11, 2014 - 12:11 AM
Still up looking for these tractors lol this could get expensive quick must resist buying the first ones till I have all the info and a good deal
#3 Talntedmrgreen ONLINE
  • 3,290 Thanks
  • 2,318 posts
Posted August 11, 2014 - 09:08 AM
Tim, the Powermax tractors (and their Allis counterparts) are very popular machines.  There were improvements in later models and options available that drive higher values.  Generally, a decent, running 4040 Powermax or Allis 620 can be had in the $1500 range.  All have a 2 speed rear end, most have 3pt hitch, but few have a working rear PTO (2000rpm).  Attachments such as deck, dozer, blower are fairly common, and run $250-600 each, depending on condition.  Other popular and harder to find attachments can run higher...Sweepster, Snow cab (hard and soft), 48" tiller, etc.  Nonpowered Cat0 and Cat1 attachments for the 3pt are very common, and reasonably priced locally.
Auxiliary hydraulics, rear PTO, engine upgrades all drive value higher.  Onans are typically thought of as expensive to fix, and many of these tractors now use a Briggs Vanguard or Honda Vtwin.  Later models have an upgraded front axle setup that is favored vs the earlier type.  Loaders can be found for folks with a decent budget.  These tractors do lack power steering, whoever, which is unfortunate.
VS a 4020, attachments are probably harder to find, but around the same price.  The 4020 will be a bit smaller, but arguably as capable.  The hydrive system is tough to beat.
#4 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 11, 2014 - 12:02 PM
What is the difference between the 620 and 720
#5 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 11, 2014 - 12:04 PM
Did any of these have a locking diff on them ?
#6 skifoof OFFLINE
skifoof
  • 54 Thanks
  • 86 posts
Posted August 12, 2014 - 09:50 PM
I have a 620 and 720,i personally like the decal on 620 better,differences I know are decal on hood,720 has a safety lockout on 3 speed shifter,front steering castings bigger on 720 although I argue they are any better how would u ever break it...axles front end identical,also some 720's where called (specials) a lower cost version where 3pt rear pto hour meter where a option,not everyone needed this,also I noticed on specials you got a 2 u shaped springs under seat versus adjustable version on a normal one were u had a lever to slide back and forth,electric clutches are different also,one better than other,no, not in my opinion,black grill on 720 white on 620,they are plentiful around my area and into Minnesota there are always on craigslist,nice one on there now,far as locking diff,u don't need one ,both wheels grab hard,i know! only flaws I see r no power steering and I think the onans are underpowered for the size of them,as far as prices,you wont find one out here for 1,500,there usually 2500-5,000 for nice ones
Edited by skifoof, August 12, 2014 - 09:52 PM.
#7 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 15, 2014 - 12:53 PM
I have found some but boy they have been proud of them one guy said he has one beside his barn that has not ran in three years he would take 2000 dollars for it
#8 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted August 15, 2014 - 01:25 PM
We bought a Simplicity 4041 which is the same as the A/C 720 with the 19.9 HP CCKB Onan. It is a horse of a tractor.
#9 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted August 15, 2014 - 03:22 PM
Tim, you can take a look at this thread and send the guy a PM to see if it's still available.
http://gardentractor...nd-front-blade/
#10 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 15, 2014 - 11:30 PM
Yeah I replied to that and never got a bite thanks for the suggestion
#11 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 15, 2014 - 11:37 PM
Ok I got a deal working on a big ten. A had a 4020 case for two hours and the guys kid called me in tears begging me to sell him his dads tractor cause it meant so much to him and I am working a deal on a power max simplicity with a dead cyl what a crazy month what do you guys think I should pay for the tractor with a dead cyl I think it is the dreaded valve seat
#12 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 16, 2014 - 08:48 PM
Ok I need a lot of info on the onan cckb motor that is in this thing I have found two that are not running and one the guy says it has 110 compression I but won't start
#13 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted August 17, 2014 - 12:59 PM
More then likely it's a bad coil and or points/condenser. Also make sure you have 12vts to the coil, maybe a bad connection at the ignition switch or at the engine plug in down by the starter where the wiring harness plugs in to the engine wiring. I have had the issues with our 4041 SIM.. I have an ignition switch that you can turn past the point where the coil feed doesn't send power to the coil, maybe that is your issue.
There is a thread about it here,
http://gardentractor...041-simplicity/
#14 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 17, 2014 - 02:19 PM
This guy wants 1200 for it and the rear pto clutch is not kicking in simple test on that with the power probe an electrical lifesaver and it won't spark and both cyl have 110 compression what do ya think
#15 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 17, 2014 - 02:48 PM
Oh and it comes with a snow caster no mower deck
