Cub Original Breather Issues
2 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted August 10, 2014 - 09:26 PM
I just got a cub original last week and I got it running. It doesnt smoke at all. But when I go through tall grass, up a hill, or try to work the engine it boggs down. Today I noticed a lot of smoke coming out of the breather and oil collecting where the breather vents. Does this mean I got a bad compression or is there an issue with the read valve in the breather and the engine is loosing vacuum. Im new to kohler k series, i normally work on briggs and stratton, so any advice would help
#2 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted August 13, 2014 - 10:53 AM
This happened to me with my Kohler K321 on my Ford LGT 145.
It was due to bad ignition timing because my points were pitted and corroded. Once I changed the points and condenser the problem went away.
Give that a try.
#3 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted August 13, 2014 - 07:13 PM
I will have to do that. when i remove the plug and check spark it is blue which means its hot.  I also got the timing set a 22 degrees btdc.  but i got two condensers on the coil. i dont know if the original one is bad so i added another, seemed to help some but its still not good
