What Did I Do?
7 replies to this topic
#1 rgfoote OFFLINE
rgfoote
  • 1 posts
Posted August 10, 2014 - 11:59 AM
2006 SLT  after I cleaned carb (thanks guys, runs great!)I replaced the drive belt. Now it has a much reduced pulling/pushing performance, and rolls on a hill. before you could not push it down a hill without disengaging the trans with the lever/rod in back. I could move my heavy boat, now the tranny groans without pushing my empty trailer.
Any idea what has happened?
#2 HDWildBill OFFLINE
  • 8,984 Thanks
Posted August 10, 2014 - 12:15 PM
Welcome to GTT.  When you replaced the drive belt are you sure you got it on the tensioner correctly?
#3 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted August 10, 2014 - 12:17 PM
Incorrect size, style, or positioning of belt.
#4 boyscout862 OFFLINE
  • 13,549 Thanks
  • 9,427 posts
Posted August 10, 2014 - 01:08 PM
Welcome to GTT. See above. Once it is fixed, relax and enjoy the site. Good Luck, Rick
#5 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,245 Thanks
  • 6,065 posts
Posted August 10, 2014 - 01:22 PM
Welcome!!   :wave:
The tranny release could be partially on as well..  Just a thought..
  • HDWildBill and boyscout862 have said thanks
#6 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted August 12, 2014 - 07:55 PM
Welcome to GTT.
As already mentioned, make sure the belt path is correct.
Is it an OEM belt?
I'm guessing 2006 is the model year.  I found the following site that shows a parts break-down for a 1554.
http://www.partstree...dn=6901652D0003
There are a couple idler pulleys.  They may be mounted on plates that have springs to hold tension.  Make sure it didn't pop off when the old belt was removed.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 12, 2014 - 09:41 PM
Welcome!!   :wave:
Cat is not welcome.  I don't know why you said that.  :smilewink:
Ben W.
#8 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,245 Thanks
  • 6,065 posts
Posted August 12, 2014 - 10:21 PM
Ben W.
The Welcome was for rgfoote!  (the original Poster!!)   :D
  • superaben said thank you
