Simp Sunstar Plow Help
4 replies to this topic
#1 skidduht OFFLINE
skidduht
  • 33 Thanks
  • 25 posts
Posted August 10, 2014 - 10:18 AM
I have pretty much decided to keep my sunstar and fix it up and run it. I got a plow with it but its the standard simplicity plow, that mounts where the mower deck does. how do i hook up the hydro lift? I was given no mounting brackets or linkage with the plow. Or do i need a plow that mounts in the back of the tractor with a long frame so i can just hook it on the deck lifting chains? Thanx
#2 boyscout862 ONLINE
  • 13,554 Thanks
  • 9,430 posts
Posted August 10, 2014 - 10:32 AM
I'm not sure what you have. Please post some pics of the tractor and the plow. Then we can help you. Good Luck, Rick
#3 skidduht OFFLINE
skidduht
  • 33 Thanks
  • 25 posts
Posted August 10, 2014 - 11:03 AM
Here's the plow &tractor
#4 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 10, 2014 - 11:17 AM
Doesn't appear to be the right plow for your Sunstar.
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted August 10, 2014 - 12:52 PM
That plow is for the tractors built in the mid 70's, not for a Sunstar I think. Does it measure 42" across? The mounting frame is similar for a SS, but the two bars bent and welded together are for the older units. I can't tell if the plow has the slot for the angle cylinder.
