My new purchase......Snapper/MF 4820 snowthrower!
42 replies to this topic
#31 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 23, 2018 - 04:56 AM
I will get some pics and measurements tonight after work for ya. These are nice machines. And yes very hard to find. Good luck .
  • KennyP and pappysMF have said thanks
#32 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 23, 2018 - 06:12 PM
Ok.. So I got pics, but my son ran off with my only tape measure. Will get measurements later .
  • olcowhand, DMAX and pappysMF have said thanks
#33 pappysMF OFFLINE
pappysMF
  • 131 Thanks
  • 113 posts
Posted January 23, 2018 - 08:04 PM
Thank you very much for the pictures! At this time don’t worry about any measurements, I know its cold up there. The pictures will greatly help with us getting it mounted and working.
  • limebuzz said thank you
#34 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 23, 2018 - 10:16 PM
Good luck. If you need more pics just ask
  • pappysMF said thank you
#35 pappysMF OFFLINE
pappysMF
  • 131 Thanks
  • 113 posts
Posted January 24, 2018 - 04:39 PM
Limebuzz, would you be able to get a measurement of the sprocket that runs the chain to the auger please? I want to be sure it is the correct size before I replace it and the shaft. Here is a picture of the one thats on it now. As you can see, mine is hacked up pretty good and the previous owner tried to weld it to the shaft.
Thank you!!
Edited by pappysMF, January 24, 2018 - 04:41 PM.
  • olcowhand and limebuzz have said thanks
#36 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 24, 2018 - 07:40 PM
Something so easy you would think. But oh no..... they have that sprocket tucked up under a big bracket. So, I'm done early tomorrow, so I will pull blower off and tip it up and check it out for you
#37 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 25, 2018 - 04:42 PM
Thats quite the hack job they did to that blower. looks like the correct sprocket. Mine has 20 teeth.Can't get in there with a tape,or a camera.
#38 pappysMF OFFLINE
pappysMF
  • 131 Thanks
  • 113 posts
Posted January 25, 2018 - 08:45 PM
Mine sprocket has 20 teeth and is about 3 1/2’ across. I wonder if the previous owner did change the size of the sprocket then?
#39 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 26, 2018 - 04:40 AM
I'd say yours is original if it's a 20 tooth.
#40 pappysMF OFFLINE
pappysMF
  • 131 Thanks
  • 113 posts
Posted January 26, 2018 - 06:19 PM
Okay, so then I should be good running it off of the front PTO then?
#41 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 26, 2018 - 08:16 PM
Right on. You have the gearbox and all?
#42 pappysMF OFFLINE
pappysMF
  • 131 Thanks
  • 113 posts
Posted January 26, 2018 - 08:25 PM
Yes, I think I think I have everything else I need besides the lifting gear. Again, I want to thank you for all of the help and Info.
#43 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted January 26, 2018 - 09:19 PM
That's good, cause I think it would be next to impossible to find them parts separately. Let me know when you need some measurements. Good luck
