Squeal Coming From Under Seat Of A Gt6000
29 replies to this topic
#1 aaronsGT OFFLINE
aaronsGT
  • 13 Thanks
  • 18 posts
Posted August 08, 2014 - 07:40 AM
I just purchased a GT6000 model 917.255981.  It came with 44" mower deck and snow plow, weights, and chains.  Im keeping the plow, weights, and chains and want to sell tractor with deck.  There is this loud squeal that comes from under the seat.  It happens while driving or when the tractor is off and in neutral and I push it.  I haven't had a chance to check the oil in the rear axle.  Has anyone had this before and able to fix it or does anyone have any suggestions?  I'm not wanting to put a lot of money into it.  If it ends up being the rear end is shot, I'll probably just part it out.  I only paid $320 for it all.  So I should be able to get most bad from the deck and engine and wheels.  The Koehler engine seems good, I just need to replace the solenoid. Thanks for any help.
#2 MH81 ONLINE
  • 28,902 Thanks
  • 29,273 posts
Posted August 08, 2014 - 08:19 AM
With those symptoms and the fact that it happens in N also' check the brake assembly.
And :welcometogttalk:
#3 Gabriel OFFLINE
Gabriel
  • 1,440 Thanks
  • 1,858 posts
Posted August 08, 2014 - 09:16 AM
WELCOME!
#4 LilysDad ONLINE
LilysDad
    --Crazy about GTTalk-- 'sort of'
  • 10,996 Thanks
  • 8,398 posts
Posted August 08, 2014 - 11:01 AM
Last time that happened to me, a squirrel had got stuck under there!
#5 TAHOE ONLINE
TAHOE
  • 7,182 Thanks
  • 5,279 posts
Posted August 08, 2014 - 11:06 AM
Welcome!!!
My bet is there is an idler pulley under there with bad bearings.
#6 Cvans OFFLINE
  • 5,224 Thanks
  • 5,440 posts
Posted August 08, 2014 - 11:11 AM
my bet is there is an idler pulley under there with bad bearings.
:iagree:
#7 aaronsGT OFFLINE
aaronsGT
  • 13 Thanks
  • 18 posts
Posted August 08, 2014 - 01:43 PM
Thanks for the help so far and the welcome.  Just found this site.  Always nice to have as much advice as possible.  Heading camping tonight, but I will check the brake first and then the idler pulley when I get back.  Nothing has jumped out and bit me yet, and I haven't seen any fur or smelled anything dead, so I'm leaning against the squirrel. I forgot to mention that its not a constant noise, while driving, it squeals for a second or 2 then stops for a second or 2 and repeats.
#8 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted August 08, 2014 - 02:33 PM
Welcome to GTtalk and I'd guess the brake??
#9 MH81 ONLINE
  • 28,902 Thanks
  • 29,273 posts
Posted August 08, 2014 - 02:57 PM
It is a squeak and not a groan, correct?
#10 KennyP ONLINE
  • 32,214 Thanks
  • 42,024 posts
Posted August 08, 2014 - 06:53 PM
:wave: Welcome to the forum! I lean towards the brake or something rubbing a pulley. Especially the main large drive pulley on the tranny! It may be bent just a little.
#11 motobreeder ONLINE
motobreeder
  • 427 Thanks
  • 615 posts
Posted August 08, 2014 - 08:24 PM
Sounds like the brake material may be gone - metal on metal brakes?
Or, do you have a small child with a finger caught under the seat? :rolling:
#12 aaronsGT OFFLINE
aaronsGT
  • 13 Thanks
  • 18 posts
Posted August 09, 2014 - 05:47 AM
I hope its not the large drive pull on the tranny. At least sears doesn't sell that part any more.
#13 KennyP ONLINE
  • 32,214 Thanks
  • 42,024 posts
Posted August 09, 2014 - 05:59 AM
I'm leaning more towards the brake. But if you can, put the rear up on stands so you can turn the back wheels and look under while turning them. You should figure out what it is real quick. Could be something has worn some and rubbing where it shouldn't.
#14 aaronsGT OFFLINE
aaronsGT
  • 13 Thanks
  • 18 posts
Posted August 13, 2014 - 06:43 AM
Well it looks like the brake shoe just needed adjusted. Waiting for solenoid today then will test driving to make sure that was the noise.
  • MH81, KennyP and Cvans have said thanks
#15 KennyP ONLINE
  • 32,214 Thanks
  • 42,024 posts
Posted August 13, 2014 - 06:49 AM
Glad it was simple!
