How To Price A Case D100 646 Series
tractor case
5 replies to this topic
#1 llblack22 OFFLINE
llblack22
  • 1 posts
Posted August 07, 2014 - 09:26 PM
I need to figure out how much an old Cas d100 646 series garden tractor is worth.  Its my parents and I need to sell it or get it running.  I need help figuring out how much it is worth.  Any helpers out there for me?  Thank you
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted August 08, 2014 - 05:06 AM
Welcome to GTTalk. Check on Ebay or equipmentfinder etc. for the same tractor. It will vary a lot with condition and location.
#3 Oldford OFFLINE
Oldford
  • 1,135 Thanks
  • 786 posts
Posted August 08, 2014 - 10:17 AM
Hard to say, what year?   72-74 red/yellow, 75-80 brown.  Serial# tells age.   Like any machine location & condition.  Pics? history? usage? etc.
If can't get it running worth a lot less, like 1/2, rebuild a cck onan can cost same as repower, $2k range.  Obsolete motor.  Check compression both holes, spark, etc.  Can't get running can't check hydraulics, can't move around easy... can't load it... heavy machines.  Does it have the belly weight?
Running one in upstate NY didn't sell on ebay last month for $4800 if that helps.  seems to be activity in ohio region.  good luck, post up some pics
#4 Tim Bergfeld OFFLINE
Tim Bergfeld
  • 219 Thanks
  • 449 posts
Posted August 08, 2014 - 11:20 AM
Pics are key I am always looking for a new project if the money is right
#5 twostep OFFLINE
twostep
    Rockstar
  • 1,988 Thanks
  • 2,539 posts
Posted August 08, 2014 - 02:24 PM
A neighbor has one of these. They are worth quite a bit even in rough condition. it's hard to put a number on it without seeing it though.
Even though they aren't very big in size they are built twice as heavy as any GT... I consider the 600 series a sub-compact industrial. The D100 is a Davis backhoe. The belly weight on these things are rediculous.
#6 NyRedNeck OFFLINE
NyRedNeck
  • 86 Thanks
  • 126 posts
Posted August 14, 2014 - 02:58 PM
Call Steve Guider. He lives in Ohio and knows these machines quite well.
(937) 363-3523
Also tagged with one or more of these keywords: tractor, case
