Turing Way Too Sharp
4 replies to this topic
#1 akretowicz OFFLINE
akretowicz
  • 236 Thanks
  • 316 posts
Posted August 06, 2014 - 08:52 PM
I have a 1054 which I love, except it turns so sharp it cuts into the lawn badly.  Is there anything that could be done as far as adjustments, etc.?  Sure would appreciate any advice someone could give me here.  Thanks.
#2 UncleWillie ONLINE
  • 16,254 Thanks
  • 8,971 posts
Posted August 06, 2014 - 09:05 PM
Dont turn so fast maybe?
  • Bill 76 said thank you
#3 MH81 OFFLINE
  • 29,978 Thanks
Posted August 06, 2014 - 09:22 PM
Any way to build a stop? Also, wheels out of alignment will do that faster.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted August 06, 2014 - 09:31 PM
Try raising the psi in the front tires, if they are low. Firming them up might have them biting in less.
  • UncleWillie said thank you
#5 Alc OFFLINE
  • 7,227 Thanks
  • 7,579 posts
Posted August 07, 2014 - 05:36 AM
Not sure what tires your using but when I needed new front tires on the 318 I switched  to a Carsile  straight rib , they don't cut into the grass at all compared to the turf type the was on it
http://www.carlislet...garden-golf/Ti9
  • akretowicz said thank you
