St16 Head? Exhaust Port Stripped
st16 exhaust port stripped
18 replies to this topic
#1 aliwildatwork OFFLINE
aliwildatwork
  • 33 Thanks
  • 36 posts
Posted August 06, 2014 - 04:24 PM
Fellas, need some help either locating a head for this old girl or some options for the stripped exhaust port, planing it, tapping it?
Anyone with a parts machine out there?  only a few weeks left to get her running for the parade!  One screw hole is okay.  Threads on inside striped out completely, so no chance of threaded pipe going in.  the second screw hole is stripped too! Not trying to spend a ton of bucks.
#2 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted August 06, 2014 - 04:36 PM
Just a thought, can you come up with some way to make the holes studs? I have had luck in the past with laying thin pieces of soft copper in the holes and letting it form to make new threads. Not a perfect fix, but maybe plan B.
I would PM each of the site sponsors and see if anyone has the parts you need.
  • aliwildatwork said thank you
#3 JDBrian OFFLINE
  • 9,599 Thanks
Posted August 06, 2014 - 04:49 PM
I'd take a shot at tapping that second stripped bolt hole. Do you think a machine shop would be able to re thread the pipe thread? It might be cheaper to find another part if you have to get a machine shop involved.
#4 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,620 Thanks
  • 9,436 posts
Posted August 06, 2014 - 06:20 PM
Can you drill out and rethread the two bolt holes?
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 06, 2014 - 07:23 PM
Helicoil?
http://www.helicoil.in/
Available at some auto parts stores.
Tapping to a bigger size is worth a shot.
  • propane1 and aliwildatwork have said thanks
#6 KC9KAS OFFLINE
KC9KAS
  • 5,266 Thanks
  • 4,640 posts
Posted August 06, 2014 - 07:32 PM
Clean the exhaust port and get a pipe tap (mine are 1" NPT) and re-thread the internal threads for a screw-in muffler.
#7 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted August 07, 2014 - 08:22 AM
I would either try to re-tap the inner larger hole as stated or it maybe easier to get tap for and drill/ tap or helicoil the two smaller flange holes.
You will most likely only be able to find a used head on Evilbay, maybe $100 if you get lucky.
#8 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,053 posts
Posted August 07, 2014 - 09:26 AM
What model engine?
#9 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted August 07, 2014 - 11:39 AM
Oh16 I believe.
  • Bolens 1000 said thank you
#10 Bolens 1000 ONLINE
  • 14,809 Thanks
  • 18,053 posts
Posted August 07, 2014 - 12:20 PM
I have the head NOS if your interested for the OH160
http://gardentractor...der-head-33465/
#11 aliwildatwork OFFLINE
aliwildatwork
  • 33 Thanks
  • 36 posts
Posted August 08, 2014 - 02:10 PM
Do we know if this is the same as the sears ST16 OH160?  It would seem reasonable to believe...
#12 MH81 OFFLINE
  • 29,963 Thanks
  • 29,757 posts
Posted August 08, 2014 - 02:59 PM
Your best bet would be to look at the 143.xxxxxxx number on your cowling. The exploded view should still be available at sears parts direct website and you can check by part number.
BTW, I am about 98% sure it will work, but it would be better for you to verify before ordering.
#13 TAHOE OFFLINE
TAHOE
  • 7,748 Thanks
  • 5,583 posts
Posted August 08, 2014 - 03:03 PM
Yep, Tecumseh only built one OH160 for all makes. May have Different model numbers, but all the same part.
you can use a head from an OH120, 140 also I believe. The OH180 is slightly different.
#14 aliwildatwork OFFLINE
aliwildatwork
  • 33 Thanks
  • 36 posts
Posted August 08, 2014 - 03:21 PM
Thanks! The part # is 33465.  I have found them all over the place online anywhere from $200-$300 dollars.  Even found a whole engine for $300 with free shipping on ebay. Wondering what the best plan of action should be...buy the new part?  Buy the parts tractor? Buy an engine? I'd rather spend as little as possible as the tractor is pulling a float for a fundraiser event in Oct.  I'm afraid if I get the other tractor I'd wind up restoring it too...
#15 aliwildatwork OFFLINE
aliwildatwork
  • 33 Thanks
  • 36 posts
Posted August 10, 2014 - 06:25 PM
Ordered new head.  Shipping on Monday.
Also tagged with one or more of these keywords: st16, exhaust port stripped
