Variable speed adjustment on the Massey MF 12.
32 replies to this topic
#31 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted August 20, 2013 - 08:04 PM
Good stuff glad you got it working right.
One thing I did on my MF10 was to drill and install some extra grease fittings, so I could get some lube in without taking it all apart.
Brake Pedal
Clutch Pedal
Vari-Drive control handle, 1 on inside and 1 on outside.
Implement lift
PTO pedal
+ the front end
I know the clutch goes down easier now.
  • MH81 and DanP have said thanks
#32 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted August 20, 2013 - 09:20 PM
I think you're brake is set a turn to tight?
You might be able to disconnect the rod and see if the clutching works right, just don't let it hang on the ground in case the tractor moves.
Great triage.
#33 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted August 20, 2013 - 10:25 PM
THANK YOU MH81
You're very welcome. Glad it was easily solvable. :thumbs:
  • Willsmith123 said thank you
