Touching Up A Powder Coated Tractor
9 replies to this topic
#1 Rock farmer ONLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 05, 2014 - 09:14 PM
I just got my first Bolens.
Two of them actually.
These tractors are powder coated from the factory.
I will need to do some repainting.
Any advise from people who have "been there, done that"?
Thanks!
Joe
#2 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 05, 2014 - 10:54 PM
  Powder coat is great for something you'll never use. Just one little knick in it and once the rust gets started under it, it starts peeling off. I have no advice on refinishing except to sandblast.
                                                    Mike
  • Rock farmer said thank you
#3 Alc ONLINE
  • 6,747 Thanks
  • 7,398 posts
Posted August 06, 2014 - 05:35 AM
Mike , if it's just a chip and all you wanted to do was a touch-up , is there anything that could be done with out a full blown , remove and repaint ?
#4 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted August 06, 2014 - 05:46 AM
It sure is hard to remove without a sandblaster. If you can get by with touching up I'd try that first. What model Bolens did you get?
#5 Rock farmer ONLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 06, 2014 - 06:03 AM
I got an HT 20 and an HT 23.
I was thinking I won't be able to just paint over that stuff.
Looks like it would take forever to sandblast it off!
The hoods aren't so bad, but the seat pans really need to be refinished!
Thank,
Joe
#6 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted August 06, 2014 - 08:33 AM
You could try a rust converter, like RustOff!, to kill the rust and then apply primer & top coat.  Might delay the inevitable.
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 06, 2014 - 09:51 AM
  I have no love for powdercoat. As I said it's only good for something pretty that will never be used. Besides sandblasting a flap disc will work if it can get in the area needing sanding. Or maybe a dremel w/ a coarse stone. If you have lots of patience it can be feathered. I'll use Flood Penetrol as the primer and paint on any bare metal.
        Mike
  • Alc and Rock farmer have said thanks
#8 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted August 06, 2014 - 11:00 AM
Thank,
Joe
Nice tractors. I'd try working on a small area to see how difficult it is to remove. Would a chemical stripper work? That can take a lot of the labor out of the job.
#9 TomLGT195 OFFLINE
TomLGT195
  • 3,699 Thanks
  • 2,762 posts
Posted August 06, 2014 - 02:36 PM
 Joe , where's the pics???? sorry no help with the powder coat ?
#10 Rock farmer ONLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 07, 2014 - 08:33 AM
Pictures of the tractors are over in the Bolens section under HT 23.
  • TomLGT195 said thank you
