Kohler Courage 23Hp, Surges Then Dies....help
20 replies to this topic
#16 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted August 27, 2014 - 10:34 AM
I've got to suspect the float or its valve. The float could be sinking. There could be a problem with the float valve seat where it can't seal in certain positions. Good Luck, Rick
Yeah, I am thinking the same thing. Maybe a pin hole in the float? It slowly fills up with gas and no longer floats?
I ordered the carb, so I should know soon.
Edited by tweidman, August 27, 2014 - 10:36 AM.
#17 MH81 OFFLINE
  • 29,979 Thanks
Posted August 27, 2014 - 11:23 AM
Todd, how much was it?
#18 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted August 29, 2014 - 03:01 PM
It was only $50, which is why I did not bother to rebuild the existing carb.
http://tewarehouse.com/04-1050
I installed the new carb and adjusted it. It is running fine again, but time will tell if that actually fixes the problem.
I sure hope so...
Edited by tweidman, August 29, 2014 - 03:04 PM.
#19 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted September 04, 2014 - 09:20 AM
Mowed for 3+ hours last night and the tractor ran great.  I hope this continues and the new carb did the trick.
#20 Howling OFFLINE
Howling
  • 1 posts
Posted June 07, 2017 - 06:01 PM
I know this is an old post but my 27hp courage just started doing this. Curious if the carburetor fixed the issue.
Sent from my SCH-I545 using Tapatalk
#21 KennyP ONLINE
  • 40,925 Thanks
  • 47,117 posts
Posted June 08, 2017 - 05:06 AM
:wave: Welcome to the forum. The OP has been back online since Aug. of last year. I would guess the carb fixed it.
