Help Identifying Homelite Chainsaw And Locating Manual Etc.
9 replies to this topic
#1 nglauer OFFLINE
nglauer
  • 412 Thanks
  • 362 posts
Posted August 04, 2014 - 11:53 PM
I bought my grandfathers property last December and acquired some of his tools in the process. He passed away September before last - so it's hard to figure out the age of some items. I recently discovered a very well taken Homelite Super XL chainsaw and need help figuring out where to get a manual. I'd also like to know the age and if any parts are available for it.
It has the following markings:
Homelite Textron
UT NO. 10045C
SER NO. HK1320047
It is red, and although I didn't measure the bar - it is a fair size. It's dirty in the pictures... mainly because I used it to cut a few trees down along with numerous tree tops and a few storm damaged trees. It's a hefty feeling machine with lots of torque. I'm used to using Dad's Stihl which seems to crank more RPM's.. but doesn't seem to power quite like this machine.
Anyways, I didn't think it would start - considering the last time it was used was probably 10 years ago if not much longer. I'm assuming it must date back into the 90's.. but any help identifying a year would be great.
Thanks!
Nick
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 10,997 Thanks
  • 5,972 posts
Posted August 05, 2014 - 02:24 AM
Need parts?  Click HERE
I've got an old McCullough (circa 1970) in the shop now..  Needless to say parts are hard to find..
Here's a manual but not for the same Model..  Maybe it will help..  Take a LOOK
Edited by WNYTractorTinkerer, August 05, 2014 - 02:27 AM.
#3 Bolens 1000 OFFLINE
  • 15,270 Thanks
  • 18,229 posts
Posted August 05, 2014 - 05:02 AM
Nice Saw, Parts are still available Cant help you on a manual though.
If you cant find them else where I can get most air filters,chain,carb parts ect.
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 05, 2014 - 05:33 AM
Dad had one of those a long time ago. It was a great saw. Plenty of power as I recall.
#5 tyler OFFLINE
tyler
  • 57 Thanks
  • 140 posts
Posted August 05, 2014 - 07:01 AM
Model: SUPER-XL
MANUFACTURED BY:
HOMELITE CORPORATION
PORT CHESTER, NEW YORK, U.S.A.
SERIES OR ASSEMBLY NUMBER:
10045C
YEAR INTRODUCED:
1967
YEAR DISCONTINUED:
1968
ENGINE DISPLACEMENT:
3.55 cu. in. (57.4 cc)
NUMBER OF CYLINDERS:
1
CYLINDER BORE:
1.8125 in.
PISTON STROKE:
1.375 in.
CYLINDER TYPE:
Aluminum with chrome plated bore
INTAKE METHOD:
Reed valves
MANUFACTURER ADVERTISED H.P.:
WEIGHT:
13 lbs. 14 oz. (5.96 kg) powerhead only
OPERATOR CONFIGURATION:
One Man operation
HANDLEBAR SYSTEM:
Rigid
CHAIN BRAKE:
none
CLUTCH:
Centrifugal
DRIVE TYPE:
Direct
CONSTRUCTION:
Die cast magnesium
MAGNETO TYPE:
Flywheel type
CARBURETOR:
Walbro SDC or Tillotson HS
MAJOR REPAIR KIT:
K10-SDC for Walbro
RK23-HS for Tillotson
MINOR REPAIR KIT:
#6 tyler OFFLINE
tyler
  • 57 Thanks
  • 140 posts
Posted August 05, 2014 - 07:22 AM
Model: SUPER XL AUTO
MANUFACTURED BY:
spacer.gif?OpenImageResource HOMELITE CORPORATION ecblank.gif spacer.gif?OpenImageResource PORT CHESTER, NEW YORK, U.S.A.
ecblank.gif 10045C
YEAR INTRODUCED:
YEAR DISCONTINUED:
spacer.gif?OpenImageResource 3.55 cu. in. (58.2 cc)
spacer.gif?OpenImageResource 1
CYLINDER BORE:
spacer.gif?OpenImageResource 1.8125 in. (46 mm)
PISTON STROKE:
spacer.gif?OpenImageResource 1.375 in. (34.9 mm)
CYLINDER TYPE:
spacer.gif?OpenImageResource Aluminum with chrome plated bore
INTAKE METHOD:
ecblank.gif Reed valves
ecblank.gif 3.33 SAE @ 7,500 RPM
WEIGHT:
ecblank.gif 13 lbs. 14 oz. (6.3 kg) powerhead only
ecblank.gif One Man operation
HANDLEBAR SYSTEM:
ecblank.gif Rigid
CHAIN BRAKE:
ecblank.gif none
CLUTCH:
ecblank.gif Centrifugal
DRIVE TYPE:
ecblank.gif Direct
CONSTRUCTION:
ecblank.gif Die cast magnesium
MAGNETO TYPE:
ecblank.gif Breaker point or electronic
CARBURETOR:
ecblank.gif Tillotson HS-4D, HS-142A
Walbro SDC
Zama
MAJOR REPAIR KIT:
ecblank.gif RK-23HS for HS-4D
MINOR REPAIR KIT:
ecblank.gif DG-5HS/T for HS-4D
AIR FILTER SYSTEM:
ecblank.gif Cellulose fiber element
STARTER TYPE:
ecblank.gif Homelite automatic rewind
OIL PUMP:
ecblank.gif Automatic with manual override
MAXIMUM ENGINE RPM:
ecblank.gif 6,000, 10,000 to 10,500 no load
IDLE RPM:
IGNITION TIMING:
ecblank.gif 30 degrees before TDC. Mount stator as far clockwise as it will go on breaker point systems.
BREAKER POINT SETTING:
ecblank.gif 0.015 in. (0.38 mm)
FLYWHEEL/COIL AIR GAP:
ecblank.gif fixed
SPARK PLUG TYPE:
ecblank.gif Champion CJ6
SPARK PLUG GAP:
ecblank.gif 0.025 in. (0.63 mm)
CRANKSHAFT MAIN BEARINGS:
ecblank.gif Caged needle roller
FUEL TANK CAPACITY:
ecblank.gif 24.2 oz. (716 ml)
FUEL OIL RATIO:
ecblank.gif 32:1 with Homelite oil
RECOMMENDED FUEL OCTANE:
ecblank.gif Regular
MIX OIL SPECIFICATION:
ecblank.gif Homelite chain saw mix oil
CHAIN PITCH:
ecblank.gif 3/8 in.
CHAIN TYPE:
ecblank.gif Homelite38 Raker III and Oregon 72
BAR MOUNT PATTERN:
ecblank.gif 14 link
SHORTEST GUIDE BAR SUPPLIED:
ecblank.gif 16 in. (40 cm)
LONGEST GUIDE BAR SUPPLIED:
ecblank.gif 24 in. (61 cm)
COLOUR SCHEME:
ecblank.gif Homelite Red enamel
PAINT CODES:
ILLUSTRATED PARTS LIST:
SERVICE MANUAL:
  • New.Canadian.DB.Owner and WNYTractorTinkerer have said thanks
#7 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted August 06, 2014 - 09:58 AM
Best saw I ever owned was a Homelite C-55. Have no idea of age, somewhat heavy compared to todays plastic ones but a wood cutting little devil. Had it 10 yrs and changed starter rope once and the plug once. Cut 8-10 cord a yr and it didn't owe me a dime.
Mike
#8 nglauer OFFLINE
nglauer
  • 412 Thanks
  • 362 posts
Posted August 08, 2014 - 01:47 PM
I wonder what year mine is?
What is the difference in the Super XL and Super XL Auto?
Aside from the bar paint being worn off.. the saw is actually REALLY exceptional. I will have to take a picture after I clean it up and repost. It's very dirty from cutting, and is about to get dirtier in a few. I need to cut up a bunch of Pine Tree limbs that I dropped so I could get my Bolens HT and Dad's BX around the trees without snagging the ROPS or ripping one of us off our tractors lol. I used the Yellow Poland weed eater with a pole saw attachment to drop them. Talk about making life easy! Although it's awkward trying to dodge big heavy limbs with a chainsaw on a long stick lol.
Thanks again,
Nick
p.s. Do I have to use Homelite Oil? Sorry for such a newbie question... but i've never really mixed fuel for anything else in the past. I usually just steal dad's gas when i'm using his stuff. I've never had to mix any for my own stuff. Also, any suggestions on a Spark Plug, and where can I get a replacement plug wire... or maybe just the boot? The boot is cracked and it doesn't seem to snap firmly onto the plug. It doesn't effect it running, but I suppose it could pop off fairly easily.
#9 nglauer OFFLINE
nglauer
  • 412 Thanks
  • 362 posts
Posted August 12, 2014 - 01:58 PM
Found some Homelite Oil and mixed it to the 32:1 as the bottle required. However, the saw seemed to run and start 1000x better when I had it (just a small amount) running on the 50:1 Stihl mix for dad's MS250. Any idea if I would hurt anything running a different mixture?
Thanks,
Nick
#10 adamjd200 OFFLINE
adamjd200
  • 2,084 Thanks
  • 2,200 posts
Posted August 22, 2014 - 05:05 PM
Try ebay for a manual,  I use synthetic oil that makes one mix for everything, but then again I have over 30 saws. :D
  • nglauer said thank you
