Going To Build A Gt
121 replies to this topic
#106 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted August 26, 2014 - 09:18 PM
Looking good!
#107 dave8338 OFFLINE
dave8338
  • 196 Thanks
  • 374 posts
Posted August 26, 2014 - 10:40 PM
Hind sight I wish I had moved the engine forward a couple inches.
Only for weight transfer. Drive shaft angel Is fine. I know you plan on getting it mobile and taking it to the shop for final mock up. When you do, pay special attention to the area of the C-Chanel you removed. A few well placed gussets and tie them back to the engine cradle, so you can use THAT lump, as a stress member, and she'll NEVER cause you an issue.
Looking GREAT. ! ! ! ! !
#108 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted August 27, 2014 - 05:25 AM
Just wondering here , when you have a longer wheelbase will that help when using a dirt plow or any rear implements ?  I guess the drawback would be a larger turning radius ?
#109 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 27, 2014 - 05:52 AM
Not only for weight distribution but steering column room is going to be another issue.
A larger turning radius and more stability. I think it makes a firmer stanced tractor. I think mine is 2" longer than a 1450 Cub. I wanted to leave room for any deck combination I may want to use down the road.
#110 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted August 27, 2014 - 07:49 AM
The drive shaft angle will work fine.  Glad to see a universal equipped shaft in there....much stronger & simpler.  So you're gonna make an angled box at the engine cutout in the rails?
#111 junkman OFFLINE
junkman
  • 127 Thanks
  • 58 posts
Posted August 28, 2014 - 11:35 PM
Great read from begining to end! You must remember on projects like this, it usually takes way more time and money then first estimated. I know, For I have done a few, and am working on one right now. I used to work at a scrap yard, so many components got saved and stored for later use. Saves money but the wife hates it. Time is hard to find for me. I like the idea of the swelled frame for you will need shore that cut side up for strength. My GT17 Ariens is that way on both sides and it looks good. Good luck and can't wait to see it finished.
#112 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 01, 2014 - 06:57 PM
Life sucks sometimes. I had to put a water pump on the truck. I've also found out I've got a cracked head or a messed up head gasket. No funds for the gt and I won't have it done by plow day. :(
  • olcowhand said thank you
#113 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted September 01, 2014 - 09:34 PM
yeah, life gets in the way sometimes... just part of it though. what engine do you have in your truck?
#114 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 02, 2014 - 05:50 AM
The 6.5 diesel. The truck needs alot of love. It's 20yo and sat for some time before I got it. I'm looking at a 99 Chevy but I'm worried about the 6.0 and fuel mileage.
#115 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted September 02, 2014 - 07:34 AM
We have a 2001 GMC 6.0 since new , never got better then 14 mpg highway now with only 80k it's 12mpg :(  doesn't change much on short trips either
#116 TAHOE ONLINE
TAHOE
  • 7,975 Thanks
  • 5,675 posts
Posted September 02, 2014 - 07:54 AM
Sorry to hear of the troubles David, feel your pain.
Seems I fix one thing and three more break.
#117 olcowhand ONLINE
  • 41,136 Thanks
  • 31,413 posts
Posted September 02, 2014 - 09:56 AM
David....welcome to my world!  I fix one thing....2 more break.  Sooner or later we do get caught up though. .......I think!
#118 twostep ONLINE
twostep
    Rockstar
  • 1,985 Thanks
  • 2,536 posts
Posted September 02, 2014 - 02:03 PM
what do you need the big engines for? I've got a 6.0L in my truck for pulling the jeep. I wouldn't want it for DD though. I can get 14mpg empty (running 65). I can triple tow my jeep and popup and get 8.5mpg (running 75mph).
#119 IHCubGuy ONLINE
IHCubGuy
  • 1,520 Thanks
  • 1,596 posts
Posted September 02, 2014 - 04:13 PM
I got a 05' 2500 with a Duramax currently.  Around town I get 18 mpg.  On trips I get around 24 mpg.  MUCH better than my 06' GMC 1500 with the 5.3.
#120 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted September 03, 2014 - 11:03 AM
The 6.0 and 410s scared me. I went with a 93 Chevy 4x4. Good ole 350
