Going To Build A Gt
121 replies to this topic
#61 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 14, 2014 - 10:07 AM
Wow a dropped axle on a GT
I didn't drop it.  I turned it around backwards.
originally mounted on the end of the frame, not underneath
Correct but one of the things im building this for is ground clearance.
I love the look of those 520 axles
I do to and regret sending it with frankincub.  I agree 31" tires are to tall.  I think im going to go with 26"ers.  I can lower the front axle if I absolutely have to.  I need to get the tires and see how they actually fit.
#62 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted August 14, 2014 - 10:31 AM
You may have said somewhere, but why would you need all this ground clearance?  You going "stump jumping" or something?
#63 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 14, 2014 - 11:29 AM
I want to be able to lift the deck high enough to clear a 4x4. I have several rocky places in my yard.
#64 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted August 14, 2014 - 11:38 AM
That I can understand.  Best to have a shaft drive deck if you're gonna have that much deck variance, so the system off the 990 would do the job.
#65 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 14, 2014 - 11:59 AM
I can't even begin to think about deck configuration. I may do a 3ph self driven deck just because I can lol. I am getting a little excited. Bushings and gaskets have started coming in the mail. I'm guessing the oil pan will be here tomorrow. The body will be the hard part of this build.
#66 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted August 14, 2014 - 03:26 PM
You need to put on a pair of horse blinders so you can concentrate & not see shiny objects off to the side.  There's only 5 weeks till plow day ya know!
#67 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted August 14, 2014 - 04:11 PM
How about low rider aircraft struts?
#68 Sawdust ONLINE
Sawdust
  • 5,667 Thanks
  • 3,374 posts
Posted August 14, 2014 - 11:00 PM
I was being humorous about the dropped axle. It reminded me of the ole street rod days.
#69 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 18, 2014 - 12:34 PM
Im going with Maxxis Bighorn 2.0's  26" x 11" x 12" for the rear.  I think im going to have to lower the front axle to sit level.  I also have the oil pan for the engine.  It should start looking like a GT here in the next couple days.  Ill be using the seat pan from a 1450 cub.  So far its the only body panels I have figures out.  Pics to follow later this week.
#70 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted August 18, 2014 - 02:11 PM
I'm beginning to think this is going to be a tactical tractor.
  • BairleaFarm said thank you
#71 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 18, 2014 - 08:13 PM
Of course the oil pan mounting holes are a inch wider than the frame. I also can't find the wheel horse dash I had planned on using. I sat some sheet metal on the frame just to get a little I idea. I hope to have the rear tires on tomorrow night. It's sketchy the way it's sitting and I'd like it to be more stable than it is before I really start working on it.
  • olcowhand, Alc, LilysDad and 1 other said thanks
#72 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted August 18, 2014 - 10:07 PM
Looking good!
#73 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted August 19, 2014 - 06:14 PM
Tires line up great with the fronts and it sits level. I wonder if I could offset the engine like this?
Playing around with body panels. The cub fenders will need to be raised or trimmed. I like the mtd fenders to.
  • Gabriel said thank you
#74 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted August 19, 2014 - 06:26 PM
The MTD fenders look and fit better. You could make an engine mounting plate with welded in studs facing up and facing down as appropriate.
  • BairleaFarm and Sawdust have said thanks
#75 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted August 19, 2014 - 07:08 PM
:ditto:  :watch_over_fence:
