I Have A Problem.
4 replies to this topic
#1 101 senior OFFLINE
101 senior
  • 248 Thanks
  • 380 posts
Posted August 03, 2014 - 10:14 AM
I bought a JD 400 garden tractor w/ a Kohler K532 engine. The engine is a points and condenser coil engine not an electronic one. The key switch has 5 posts, M,L,S,G,B. The G and M posts have no wire to them. The tractor will start, but when you turn the switch off the tractor keeps running. I would believe that its because of those posts not being hooked up, but I do'nt have a wiring diagram to know where to run the wire. HELP.
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted August 03, 2014 - 10:17 AM
theres probaly a kill wire somewhere that came unconnected
  • 101 senior said thank you
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted August 03, 2014 - 12:50 PM
You have the wrong ignition switch.  On yours,
M is magneto
L is load
S is start
G is ground
B is battery (or "power in")
That is a switch for a magneto ignition (no power to the magneto when key is on, ground to magneto when key is off)
You need a switch for a battery ignition (battery to an "I" ignition terminal when the key is one, cut off power when the key is off.)
The part number is AM32318.
I sell them for $12 each.
Ben W.
  • Gtractor, 101 senior and trowel have said thanks
#4 101 senior OFFLINE
101 senior
  • 248 Thanks
  • 380 posts
Posted August 03, 2014 - 03:37 PM
Thanks Guys. Ben, where do I get one for $12. At John Deere?
  • superaben said thank you
#5 Cat385B OFFLINE
    HAZMAT CAT
  • 14,369 Thanks
  • 10,138 posts
Posted August 03, 2014 - 03:46 PM
The one at Deere is probably $45. SuperABen there is the one you need to talk to, he supplies parts for lots small engine stuff and is a straight shooting honest person. Just click on his name to the left of his post and on the next screen choose the 'Send me a message' tab.
  • 101 senior, Trav1s, HDWildBill and 2 others have said thanks
