Pilot Bearing Seal
11 replies to this topic
#1 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 06:59 AM
Does anyone know the part number for the seal that is in front of the pilot bearing in the flywheel?  I just figured I would replace it while I have this apart.  Found out that my snap ring was bent and causing my issues.
Thanks
#2 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 03, 2014 - 07:23 AM
Do you have the PK number or seal number itself?
I can interchange just about any seal.
  • willy1094 said thank you
#3 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 07:36 AM
I looked all over the seal and couldn't find a number.  I know the shaft is .5 and O.D.  is 1.125.  I found thie http://cgi.ebay.com/...atchlink:top:en but didn't know if it would be OK to use since it is rubberized and not just a metal case with rubber seal.
Thanks
#4 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 07:46 AM
part number mission shows is 82-0050
Edited by willy1094, August 03, 2014 - 07:47 AM.
#5 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 03, 2014 - 07:47 AM
The ones in the link are more of a dust seal, they are very thin.
#6 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 03, 2014 - 07:53 AM
If that it the correct number I can interchange it for you. Did you have a different part number listed before? I had the other number you gave in stock but this one I'd have to order for you.
#7 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 08:01 AM
Yeah, the first number was for a briggs and then I edited my post with the Kohler number.  I shot an email to Jerry Frank to see if he had any.  I was hoping I could poss find a part number to take to a KOI (automotive) store.  If you can order it I may be interested.  I need the Bushing/bearing also.  I could probably get away with reusing both but it seems silly since I have it tore apart now.
Thanks again
#8 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 08:03 AM
How much would that seal be...and do you also have the bronze bearings?
#9 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted August 03, 2014 - 08:07 AM
I'll have to let you know tomorrow on price, if you have numbers for the bronze bearings I can probably get them too.
#10 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 08:34 AM
80-0009 new number and B-9A (Plot Bearing) old number.
#11 glgrumpy ONLINE
  • 8,618 Thanks
  • 7,926 posts
Posted August 03, 2014 - 10:09 AM
Mission Manufacturing in S. Indiana has those and Jerry Frank as noted. That seal is a common one, size should be all you need like noted. I don't have it written down I guess, couldn't find it.   Not much need really as a seal there. Think just keeps oil from trans shaft and grease on bearing from getting on the clutch face, I guess. So simple, yet So Hard to do these clutches isn't it??
#12 willy1094 OFFLINE
willy1094
  • 38 Thanks
  • 72 posts
Posted August 03, 2014 - 02:52 PM
It is easy once you know what to look for and where to find the replacement.  The days of racking your brain and trying to figure it out on your own it what gets you.  I'm a person that wants to try to work things out on my own.  The simplicity, once someone tells you how to do it, just makes all the trouble you had that much worse.  LOL  One little clip that is worth pennies had me and my grandpa stumped for weeks!
