Jd 318 New To Me
318 operators manual
6 replies to this topic
#1 D318 OFFLINE
D318
  • 1 Thanks
  • 5 posts
Posted August 02, 2014 - 08:20 PM
I found an 1985 318 last week and was able to buy it reasonably, It is in good condition and runs good, I need an owner/operators manual to identify parts and maintenance items required.
  • A.C.T. said thank you
#2 Trav1s OFFLINE
Trav1s
  • 3,516 Thanks
  • 4,495 posts
Posted August 02, 2014 - 08:39 PM
:welcometogttalk:
I am sure one of the 318 owners can help you out.  If you need info on the 120/140 and the early 300 series (300/312/314/316K) I have a fair amount available.  Which deck does the 318 have?
#3 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted August 02, 2014 - 08:59 PM
Nice choice in tractors. Enjoy!
#4 Bigfoot OFFLINE
Bigfoot
  • 20 Thanks
  • 41 posts
Posted August 02, 2014 - 09:36 PM
I've got a John Deere 318 also, and find that it's a grand piece of equipment. The only thing I don't like much is those plastic headlights!! They seem to be fogged up somewhat. Other then that it's fine. Nice choice!! Good luck.
#5 hdg4400 OFFLINE
hdg4400
  • 286 Thanks
  • 351 posts
Posted August 02, 2014 - 10:04 PM
D318:
Sent you a PM about some info you asked about.
  • D318 said thank you
#6 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted August 03, 2014 - 06:41 AM
Congrats on the 318. Good ones are getting hard to find around here.
#7 D318 OFFLINE
D318
  • 1 Thanks
  • 5 posts
Posted August 03, 2014 - 07:08 AM
Hi Folks! Thanks for replying so quick.  This machine is well built and I will have many years of usage and enjoyment of owning it.
Travis the Deck is the 50 inch model. Headlights seem to be clear when they are working.  Only one was lighting up when I bought the tractor, I swapped the working bulb to the other sockets and found they still didn't work. Traced problem to the ground side of  bulbs. The problem seems to be where the black wire goes into the socket. Does anyone know if the wire is a push on tab or permanently fixed in socket? Anyone have experience with this small problem?
