Snapper Snowblower
42 replies to this topic
#31 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted October 27, 2017 - 02:12 PM
So I pulled this out of storage to get it ready for winter and a new home since I upgraded to a JD TRS21.  Took the carb apart to adjust the float only to discover it is full of gasoline.  This is no surprise as I have been using a small fuel shut-off valve I installed in the fuel line to manage fuel flow to the carb.  Still don't have the model/spec number off the little 2 stroke Tecumseh as you need to remove the engine to get to them.
#32 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted October 27, 2017 - 02:20 PM
Here is the float that it uses
#33 dodge trucker ONLINE
dodge trucker
  • 2,299 Thanks
  • 3,015 posts
Posted October 27, 2017 - 06:28 PM
dont be so fast to want to send it to a new owner.. sometimes those little 2 cycle 1-stage are just what you need, esp for walkways and such. or if you just got an inch or 2....
sunk float, seems like I have had a run of those lately.  fortunately a new float isn't that much money.
One thing that I found out on Tecumsehs... DON'T use an aftermarket needle and seat, I have done lots of those carbs over the years and EVERY SINGLE TIME that I tried an aftermarket needle and seat it has bled gas out the mouth of the carb til the tank empties out. buy, and keep a couple of those 631021 needle/seat kits around....
  • Bolens 1000, KennyP and Jazz have said thanks
#34 Jazz ONLINE
Jazz
  • 2,302 Thanks
  • 1,404 posts
Posted October 27, 2017 - 09:54 PM
I like that post ^ "every single time"  :smilewink:
#35 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted October 28, 2017 - 06:55 AM
The Deere is a single stage paddle unit and has a Tecumseh 2 stroke in it like the little Snapper but is a bit larger (24" instead of 18").  I used briggs parts to do the first rebuild and will continue to use them on my project - i agree they are a better quality.
#36 dodge trucker ONLINE
dodge trucker
  • 2,299 Thanks
  • 3,015 posts
Posted October 28, 2017 - 01:40 PM
Oh. I thought the TRS ones were2 stage units.  Deere had 2 series of 2 stage units over the years, they had one series (the better/heavier duty kind) that were actually built for them by Ariens and most had the cast iron impeller gearcase, then the TRS series, which as I remember was built by Murray.
same as equivalent machines by respective brands besides color.....
#37 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted November 02, 2017 - 09:27 AM
Still need to get a float ordered
#38 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 03, 2017 - 08:24 AM
The floats are now made plastic by tecumeh which are actually superior to the metal now with todays fuels
#39 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted November 04, 2017 - 04:48 PM
Looks like you get some more money from me and I am totally good with that!
  • Bolens 1000 and KennyP have said thanks
#40 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted November 06, 2017 - 09:27 AM
Ordered the float this morning.   :rocker:
#41 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted November 16, 2017 - 03:42 PM
New float installed and the old Snapper is all buttoned up.  Did a bit of priming after giving the float bowl a chance to fill and gave it a try.  Looking at it next to the TRS21 that I picked up to replace it makes the Snapper look really small.  I won't re-home it until I have some time with the TRS21 in the snow.  Thanks again to Bolens 1000 for the parts.   :thumbs:
  • Bolens 1000 said thank you
#42 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted November 16, 2017 - 09:43 PM
Here they are together.
#43 Trav1s ONLINE
Trav1s
  • 3,170 Thanks
  • 4,283 posts
Posted December 30, 2017 - 02:58 PM
So the little Snapper got a workout yesterday.  The first round of snow removal took place around noon and the second one was early evening.  It took on 2-3" in each round and did not miss a beat.  My only complaint is that it still leaks fuel if I do not shut off the fuel using the valve I installed.  I think the float needs adjusted down to solve that problem.  Great machine but the Deere TRS-21 will work circles around it.
