Gravely Reduction Hubs Question
7 replies to this topic
#1 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted August 01, 2014 - 10:57 AM
Before I spend money, I'm looking for some advice. I have a Model L with a set of reduction hubs that the PO mounted 8" 5 -bolt wheels with 4.80-8 snowblower tires. Does anyone know if  the currently available 12X4 5-Bolt wheels will fit the reduction hubs? From photos that I have found online, they look like they have a similar offset. That way I can mount either 5-12 or 6-12 tires and gain some ground clearance.
#2 Genem OFFLINE
Genem
  • 78 Thanks
  • 55 posts
Posted August 01, 2014 - 01:02 PM
from what i remember, all of the gravelys with gear reduction had 12 " wheels and tires. life was much easier with larger tires in loose ground and snow. gene
#3 js5020 OFFLINE
js5020
  • 684 Thanks
  • 787 posts
Posted August 01, 2014 - 04:58 PM
Ive only seen the GR's with 12" rims also.
#4 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted August 01, 2014 - 06:00 PM
I would like to mount the larger wheel and tire. I just don't know if the new 12x4 wheel will fit.
#5 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted August 10, 2014 - 08:42 AM
how would those12x4 rims work with a `62 LI......with no gear reduction on now?? Where would you get those rims ??
#6 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted August 12, 2014 - 09:31 PM
I have the gear reduction hubs. I am wondering if the offset is correct on 12x4 rims as the old Gravely rims. I am using 8x4 rims now but they do not have any offset.
#7 BcKc OFFLINE
BcKc
  • 14 Thanks
  • 57 posts
Posted December 31, 2014 - 09:51 PM
SWS,
I know it has been a time and I am sure you have it sorted but the wheel that is stock looks just like the 12" you are showing, do you have a spacer on the little wheels you have on that set of reducers? Any side pictures of it?
I have 7 - 12 tires and you can see the limited space to clear the handles and it gets mud every place, the 7" wide does float a bit also. nice thing is being able to reverse the wheel and have a wide track.
Cheers
Casey
Edited by BcKc, December 31, 2014 - 09:58 PM.
#8 shallowwatersailor OFFLINE
shallowwatersailor
  • 87 Thanks
  • 73 posts
Posted January 14, 2015 - 02:34 PM
Actually I have sold the tractor that had these hubs mounted. I found a C-8 instead. Still have the hubs and 8" wheels though, and the 8' wheels had the same offset on each side.
You might try a 1" wheel spacer to gain a bit of clearance.
