Another Unknown
11 replies to this topic
#1 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted August 01, 2014 - 05:37 AM
I`m going to an auction tomorrow and there is 2 wheel walk behind I can`t find a pic here to ID it. The most distinguishing thing about it is it apparently has a gear box connection in the front for attachments. It comes with a tiller,sickle bar mower and a grader blade all mounted out front. It has a flat hood hood with a lengthwise  crease in the middle to slant to each side and is on a steep angle with the handle bars to the gearbox that sits kind of on top of the front frame. 4 bolt hole attachment to gearbox with about a 6 inch 4 corner spacing. Tiller is attached but looks to be a newer type tiller someone has adapted to the gearbox connection. Sickle and blade appear to be of the same vintage as the 2 wheeler. Engine exhaust come out from under the hood on the right side. I can see a nameplate on upper handle bar area but can`t read it in pic. I know that's not much info but am hoping some might know what it is and any info on its worth and abilities. It has the expected surface rust but appears to be all together in pretty good shape. I`ll try to get pic up later but have to go to town for a meeting so it would be late tonite. If you want to see it and go to the trouble, go to ProxiBid and look at the Saturday aug2 menu of auctions and it`s on page 15 of the 5th annual Summer Auction in white pine Tn
Thanks for any info.
Edited by SNUFFY, August 01, 2014 - 05:40 AM.
#2 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted August 01, 2014 - 05:55 AM
Is it a Gravely?
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,309 Thanks
  • 9,781 posts
Posted August 01, 2014 - 07:06 AM
Sounds like Gravely.
Somewhere around 1975, Gravely quit using their own engine and started using a Kohler engine. This will give you a rough idea of the age.
Edited by LilysDad, August 01, 2014 - 07:09 AM.
#4 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted August 01, 2014 - 07:12 AM
It is a gravely,here is the link
https://www.proxibid...=1406894815005#
#5 MH81 OFFLINE
Posted August 01, 2014 - 07:20 AM
https://www.proxibid...CKLE-BAR-MOWER#
  • trowel said thank you
#6 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted August 01, 2014 - 05:45 PM
that's it guys .....Thanks.....what do you know about them....can cultivators be mounted behind ???other attachments. Something about the color of the tiller makes me think late model adaptation.....
Worth.... if it is complete and runs or not ??
#7 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted August 01, 2014 - 06:00 PM
You are about to walk into a completely different world, hold on to your pants.
Gravelys came with just about every imaginable attachment known to walk behinds and the models are many to pick from, IMO one of the strongest and well built walk behinds a American Manufacturing co could offer spaning the late 50's to the early 80's when it was finally dropped when Gravely was bought out.
Prices vary state by state and age, condition of the tractor and attachments, they tend to derive a higher price when compared with say a Planet Jr or David Bradley but again it depends on several factors. The early ones with the Gravely engine is one of the higher priced ones.
In the end what is it worth to you ?
Edited by trowel, August 01, 2014 - 06:04 PM.
#8 MH81 OFFLINE
Posted August 01, 2014 - 09:42 PM
I believe the tiller is newer, but still a Gravely.  It's probably off a unit 20 years newer and they still bolted up from my understanding.
#9 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted August 01, 2014 - 10:34 PM
All the attachments pictured will work with the wb shown. Rigged fuel tank, the original one must of rotted out. It's still on there, if the tag on it is still readable, it will give you the model and year it was built.
#10 GWest OFFLINE
GWest
  • 547 Thanks
  • 499 posts
Posted August 02, 2014 - 05:51 AM
That I don't think is a tiller. It is a slow-turning rotary cultivator. If you wanted to go deep you used their rotary plow.
Garry
#11 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted August 02, 2014 - 08:27 AM
thanks guys ...been looking around...saw the chain saw set up......I`m going to give it a serious look for sure !
#12 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted August 02, 2014 - 06:44 PM
well I got it Guys.....pick it up next Friday and we`ll see what we`ve got !!!
