Need Help With 916H Tiller Belt And Hydrostat Adjustment
5 replies to this topic
#1 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted July 30, 2014 - 08:32 PM
I have a 916H that I have put a 38" tiller on but I do not remember how the belt is run on it, does anyone have any pictures of how the belt goes on these??
Also, the lever that controls the forward, neutral, and reverse is out of adjustment. I have looked under the seat pan and can't figure out how to adjust it.
Right now for the hydrostat to be in neutral the lever way up into the forward position, causing the tab that presses the neutral safety switch to be too far forward, therefore I have to push the safety switch button with my finger so I can start it in neutral.
Any help would be greatly appreciated.
#2 New.Canadian.DB.Owner OFFLINE
  • 2,325 Thanks
  • 1,496 posts
Posted July 30, 2014 - 08:40 PM
#3 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted July 31, 2014 - 07:34 AM
That is for a Vickers hydro.
This is the adjustment for a Sunstrand hydro
Here is your belt arrangement...do you have the idler set?  The 38"HD tiller uses the same setup as the 36" tillers and revitalizers do.
#4 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted July 31, 2014 - 07:37 AM
#5 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted July 31, 2014 - 04:43 PM
Thanks guys, I got the tiller belt on and it is good to go. Josh, this is the tiller I got from you :thumbs:
Now, I just have to get the neutral adjusted on this thing.
#6 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted August 01, 2014 - 05:02 PM
Many thanks fella's, I got it all adjusted like it is supposed to be. :thumbs:
