Ignition Timing And The Flywheel Key
23 replies to this topic
#1 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted July 30, 2014 - 06:22 PM
I thought I would take a minute to post this. While working on the versa-matic I found that it became extremely difficult to pull start. After a while it just would not start. Upon investigation I found that the spark was weak to none. I figured points or condenser.
I pulled the flywheel and noticed that the key was sheared just a tiny bit. I would not think it would throw the timing off that much but I said hey while I have this apart lets put in a new key and see what happens. I put in a new key and bang, got huge spark and it started on the first pull. So just keep in mind next time a engine becomes hard to start. Here are some pictures of that key. It does not look all that bad.
  • Bolens 1000, hamman, JDBrian and 5 others have said thanks
#2 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 19098 Thanks
  • 11900 posts
Posted July 30, 2014 - 06:50 PM
Briggs vertical lawn mower engines are famous for this.
  • hamman, JDBrian, Bill 76 and 1 other said thanks
#3 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 30, 2014 - 07:26 PM
Yep, had this happen numerous times on these B&S engines!
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 8078 Thanks
  • 4779 posts
Posted July 30, 2014 - 07:59 PM
Yep, a key that looks like this, will cause this.
https://www.youtube....-tLIZkrLxjJEtbA
Replaced the key and (The oil seal blew) Replace it and
Larrybl
  • MyBolens1053 said thank you
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 853 Thanks
  • 959 posts
Posted July 30, 2014 - 08:00 PM
on my horizontal briggs 16hp you can get more power outta them by getting or making a flywheel advance key
  • JDBrian, Bill 76 and MyBolens1053 have said thanks
#6 Bill 76 OFFLINE
Bill 76
  • 2054 Thanks
  • 1216 posts
Posted July 30, 2014 - 08:23 PM
I wish I had nickle for every key Briggs has sold and a dime for every engine that was tossed because someone thought it was shot when it really only needed a new key.
  • GTTinkerer, lyall, JDBrian and 2 others have said thanks
#7 lyall OFFLINE
lyall
  • 2459 Thanks
  • 1722 posts
Posted July 30, 2014 - 08:26 PM
when I have problems with my B&S 5 hp motors, I also check the flywheel key
and that is usually the problem
#8 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 19098 Thanks
  • 11900 posts
Posted July 30, 2014 - 08:37 PM
Another trick on the Briggs; check the special washer under the flywheel nut. It's a cupped washer and if there are hairline cracks, it may not be cupped anymore. You won't be able to torque the nut down properly and this means it will keep shearing keys.
  • Bill56, JDBrian, Lauber1 and 2 others have said thanks
#9 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3484 Thanks
  • 2816 posts
Posted July 30, 2014 - 08:50 PM
that right there is probably the biggest fault people do when they put the flywheel back on, not getting it tight enough to keep the key from sharing off.
  • lyall, JDBrian, Bill 76 and 1 other said thanks
#10 framesteer OFFLINE
framesteer
  • 530 Thanks
  • 254 posts
Posted July 30, 2014 - 08:57 PM
Most lower hp Briggs engines use an aluminum key.  It was made from aluminum on purpose and intended to be the "weak link" when the mower struck an object other than grass.  Better to shear the aluminum key than to bend the crankshaft or break the flywheel, or damage the crankshaft.  How easy this key shears on both horizontal shaft and vertical shaft engines depends on the torque on the flywheel nut (or starter clutch).  The torque spec varies by engine model from 55 to 145 ft-lbs.  Check the engine manuals on this site for the proper spec for your model. Bigger engines require more torque. Over-tightening may split the flywheel.
#11 Bill56 OFFLINE
  • 844 Thanks
  • 2179 posts
Posted July 30, 2014 - 09:45 PM
I,'ve had this happen too. Bothersome, but a somewhat easy fix. Good part about it... I,'ve gotten many push mowers for next to nothing, because people don't know how easy and inexpensive it is to fix the problem.
#12 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted July 31, 2014 - 05:39 AM
A small amount of movement in the key will translate in a lot of angular rotation as far as TDC and timing goes. This is a good topic and thanks everyone for posting all the info. on this problem.
#13 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted July 31, 2014 - 06:20 AM
Now that I did not realize, good info thank you.
#14 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted July 31, 2014 - 09:44 AM
I have an LT Snapper rider that recently started back firing with 12 Hp vertical B&S. The PO told me to check the key, that was the same reason why he got it int he first place. Ran fine when we shut it off, back firing bad when we started back up.
I still gotta pull tins to comfirm
#15 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted July 31, 2014 - 11:05 AM
Well I hope that your issue is the key. It would be nice to know that it helped solve a problem out there.
  • TAHOE and MyBolens1053 have said thanks
