990 Deck Swappage?
8 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 30, 2014 - 05:52 PM
Did the 990s have different deck mounting over the years? Could a unicos 42" swap with my farmking 50"?
#2 Sawdust ONLINE
Sawdust
  • 5,655 Thanks
  • 3,368 posts
Posted July 30, 2014 - 08:31 PM
My 76 has a scissors lift. The later ones had a quick disconnect. I'm not sure if they would enter change. I also think some had a square shaft
& some gad a keyed shaft. I'm sure some of our 990 experts will have better info.
  • DH1 said thank you
#3 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted July 30, 2014 - 08:33 PM
That's a good question, I'd like to know also.
#4 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted July 30, 2014 - 08:34 PM
Mine must be the quick connect. Takes me 2 minutes to have the deck off and against the wall
#5 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted July 31, 2014 - 08:54 AM
The quick change decks were 42" and 50" as were the scissors style but they were not interchangeable.
#6 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted July 31, 2014 - 09:25 AM
I have a '76 deck manual that is still the scissors style so I assume '77 was the start of the quick attach decks.
edit: apparently the above isn't the case as several other MTD documents show '76 as the start of the quick attach system.
As far as the deck driveshaft interchangeability, a quick check of several deck manuals shows the same part number (717-135 or 717-0135) for all variations, 42" and 50", scissors and quick attach.
Edited by Canawler, July 31, 2014 - 08:09 PM.
#7 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted July 31, 2014 - 04:55 PM
Was there a 50' Scissors lift deck?
#8 VTXrider OFFLINE
VTXrider
  • 517 Thanks
  • 376 posts
Posted July 31, 2014 - 06:10 PM
The information I have shows no 50" for the scissors style lift. You could convert the tractor to the quick change lift. The rock shaft would need the second arm to operate the lift carriage.
  • DH1 and BairleaFarm have said thanks
#9 AverageJoe OFFLINE
AverageJoe
  • 105 Thanks
  • 143 posts
Posted August 20, 2014 - 05:45 AM
This is the problem.  The rockshaft on the earlier models has only one lift arm.  Also, I do not believe I have seen a 50" scissor lift deck.
