Speedx, The Rebuild!
18 replies to this topic
#1 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 29, 2014 - 08:55 PM
Ok even though the Speedx looks good in the pictures, its really a mess. I started to rebuild the bad areas tonite and should be able to get it back to working like it was built originally. We found the following bad things, see the pictures,
This is the poor old engine mount that someone modified. Used to be a slider, and then it became a nonworking belt tightener, We cut  it off, with a thin wheel of the 4" grinder. Lucky for me, the factory drilled holes all the way though the mount bar, so after some grind down, I punched the slugs out and now have the original holes to reuse. Once I get some 3/4 round stock purchased, I can start the process, of replace the mounting things and get it to a slider again.
Your looking at a bad picture of the place where they cut a chunk out of the frame. Have no idea what the purpose here was ,as there is no part missing.  We also have a crack in the wheel. They are cast, and since its small, I might not do anything about this.  Not sure what the heck this bearing is trying to do, looks like someone replace the factory part with this no fitting item. It does however work and turn correctly, so again, I may not fool around with. There is an amazing amount of old grease here that was paint right over, and a lot of the other paint is thin, so may repaint the whole tractor at a later date.
  • earthgrinder, MH81, Texas Deere and Horse and 5 others have said thanks
#2 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted July 30, 2014 - 05:08 AM
Hard time for me to follow all this. What model is this? Not the type frames I have on my tractors. Don't think there is supposed to be a bearing in axle, they were just bronze bushings used there and did need a lot of grease to be used there.
#3 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted July 30, 2014 - 05:11 AM
Good start there Jeff.
Mines had two tubes with two flat stock welded on top for engine mounts, back side of the right tube braket had a hinge point for the tensioner rod.
Edited by trowel, July 30, 2014 - 05:13 AM.
  • Lauber1 said thank you
#4 TAHOE OFFLINE
TAHOE
  • 8,337 Thanks
  • 5,819 posts
Posted July 30, 2014 - 08:41 AM
Grumpy, it's a Speedex walk behind, not rider.
Edited by TAHOE, July 30, 2014 - 08:41 AM.
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 30, 2014 - 08:43 AM
A Speedex walking tractor is pretty unique, especially 'round here.
#6 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 30, 2014 - 08:43 PM
Tonites playing got us almost back to a proper mounting system, then I found I needed a 13/16" drill to get the clearance the brackets need to slide freely back and forth.  I'll have to take them to the machine shop and see if they can bore out to the right size.  Next we start to remount the control handle, and get the rod back into the correct hole. Had to know off the junk part they welded on. Lucky me that someone couldn't weld, and one hammer whack it fell off on the floor.  Once I get the mount parts done and figure out the return springs. I can construct the linkage between the mount and the handle.
  • Texas Deere and Horse and trowel have said thanks
  • 14,901 Thanks
  • 15,518 posts
Posted July 30, 2014 - 09:35 PM
Looking good Jeff, is that color right for the Speedex walking tractors. I thought they were red similar to the Wheel Horse tractors?
#8 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 30, 2014 - 10:04 PM
well a couple of guys told me this was right, but I cant find any photo evidence of it so far. The color of this one seems to be the same as a Simp, or an AC tractor. I'll probably go with it for now until research shows something else.
#9 Texas Deere and Horse OFFLINE
  • 14,901 Thanks
  • 15,518 posts
Posted July 30, 2014 - 10:49 PM
Here is a link to the Speedex site with photos of both orange and red 2 wheelers. Maybe someone there might know whats right.
http://www.speedextr...elPictures.html
You already know of this site I'm sure but thought I'd post it anyway.
  • Alc and Lauber1 have said thanks
#10 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted July 31, 2014 - 03:45 AM
Mines was red, not much but in certain spots like under bolts and such, more like international harvester red but the tractor was 60 something years old so i am not 100 % sure.
Pull a bolt or two, original paint should under there someweres.
#11 MH81 OFFLINE
  • 29,979 Thanks
Posted July 31, 2014 - 06:36 AM
Great headway Jeff. Glad to see the original stuff going back on the tractor.
#12 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 31, 2014 - 05:13 PM
yes I have looked this place over and found its more confusing than working on the tractor. Don't seem to be any pattern in them, nor a general color system. almost looks like they built a different tractor every month or so. I'm thinking I like this orange paint, and when I get tried of that, it will go to pink with small green and yellow dots on it. that should keep the purists spinning for a while.
#13 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 31, 2014 - 05:17 PM
tried the bolt pulling, but someone got to it before me and what's not painted in all grease or rusted. Its a perfect example of what not to do when redoing a tractor. I cant figure out for sure what model its supposed to be, as every model C I've viewed is different in some place. I have ran across this with the WH walker also, seems like each one is an improvement over the week before unit. In the end i'll be a lot close to factory than its seen for several yrs.
  • MH81 and trowel have said thanks
#14 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted July 31, 2014 - 05:29 PM
Come on with the pink with poke-a-dots, seen pink JD, MF and Sears, why not Speedex !
I never fully knew what mines was, model C was the closest but like yours it was slightly different, there was nothing on the tractor itself by way of model/serial numbers exsept for some casting numbers, bit of a paradox.
#15 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 31, 2014 - 08:35 PM
tonight's progress got us a motor mount that now slides. By fooling around with linkage bar, I finally got an idea of what holes to use and where it should mounted to the frame. Have to thread the linkage rod and do a bit more welding to mount rods, then I should be about done. Had a another discovery moment with the paint, when I decided to pull the handle grip off and found red under it that looks to be original.
  • MH81, Texas Deere and Horse and trowel have said thanks
