Shop Addition
15 replies to this topic
#1 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted July 29, 2014 - 08:18 PM
Started clearing a couple of trees for my shop addition today, had to get my toy out to help with burning the brush pile. IMG_20140729_190449.jpg
  • GTTinkerer, hamman and sacsr have said thanks
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 29, 2014 - 09:02 PM
nice i need to get a spring assit for my 210 cause that plow is heavy
#3 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted July 29, 2014 - 09:19 PM
I put hydraulic lift on mine, it's not factory but it works great
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted July 29, 2014 - 09:21 PM
Do you have a thread on how you did that?
How big is the addition going to be?
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 29, 2014 - 09:44 PM
That be nice
#6 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted July 29, 2014 - 09:58 PM
No, I don't have a thread on the lift. The addition is going to be 12x30. Hopefully I will be able to use my shop when I get it done. I am currently storing 11 gt's plus all of my tools, wood stove, beer fridge, you know, the important things. Cat, I will try to send you a pic of what I used for the hydraulic lift on my 212.
  • HDWildBill and Cat385B have said thanks
#7 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 29, 2014 - 10:09 PM
post a pic up on here im kinda curious too
  • Sawdust said thank you
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 30, 2014 - 09:26 AM
:ditto:
#9 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted July 30, 2014 - 08:45 PM
This is the pump i used, it came off of a in/out board boat engine. I ran hydraulic lines to a cylinder that I mounted under the tractor and hooked it up to the factory rock shaft and since the pump is under the hood next to the battery it is not seen from the outside. The only thing you notice is the momentary toggle switch on the dash. I also removed the rod that goes through the lift handle so It would not latch in the different height settings. IMG_20140730_193822.jpg IMG_20140730_193814.jpg
Edited by lesmeister, July 30, 2014 - 08:55 PM.
  • Cat385B said thank you
#10 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted July 30, 2014 - 08:54 PM
This is another pump i have, it needs the motor rebuilt but it was not installed on a tractor yet so it is easier to see. The only difference between the two is the one that is on my 212 has a small resivore that I built added for extra capacity.
#11 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 30, 2014 - 09:05 PM
O so you used and electric pump where you mount your cylinder on the rockshaft or at the hitch
#12 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted July 30, 2014 - 09:45 PM
Yep, and it's hidden under the hood.
#13 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted July 30, 2014 - 09:55 PM
That's a great idea for the lift! Hope your addition project goes well.
  • lesmeister said thank you
#14 lesmeister OFFLINE
lesmeister
  • 187 Thanks
  • 167 posts
Posted August 09, 2014 - 06:20 PM
I got a little work done today, had the 212 out doing some dirt work to level up the spot where the addition will be. Here's a pic.IMG_20140809_154123.jpg
  • olcowhand said thank you
#15 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted August 09, 2014 - 06:39 PM
Where'd you get the grille emblem on the 212? It's a big one!
