Need a little advice SS12
34 replies to this topic
#16 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted February 06, 2011 - 07:31 PM
25350 would make it a '68 for sure. It is a Suburban 12. Super 12s had a different grille but are otherwise the same machine. A starter / generator and solid state ignition would be correct for the 68.
NICE FIND!!
#17 DH1 ONLINE
DH1
    Electric Tractors
  • 5,267 Thanks
  • 5,566 posts
Posted February 06, 2011 - 07:43 PM
I think it's a 68 # 917-25350 some Tecumseh engines had S/G and SSI units.
Did you see this site>newsuburban
#18 MH81 OFFLINE
Posted February 07, 2011 - 09:11 PM
Got home late from work tonight,& ran right back out the door to work on the SS12. Got the SSI pack installed & gapped, got spark. Added a little gas to the carb, & it ran for a few seconds. Optomistic, I put it all back together & tried to start it, no spark. Messed with it & took it back apart. I have no idea what was wrong, but it waited until I had ahold of the plug again & POW.
I think I had poor ground connection between the SSI and the block. Anyways, I had a little gas line leak & the usual stuff on a 40+ yr old tractor, so I didn't get it all back together, but I was able to bypass the bad gas line and shoot a few second of video. :dancingbanana:
  • MountainMichael said thank you
#19 Bolens 1000 ONLINE
  • 14,983 Thanks
  • 18,140 posts
Posted February 07, 2011 - 09:15 PM
Thanks for the Video Alan :thumbs:
#20 Bill56 OFFLINE
  • 839 Thanks
  • 2,179 posts
Posted February 07, 2011 - 09:27 PM
Glad you are "up and running", Alan!
Thanks for sharing the video.
#21 caseguy OFFLINE
  • 1,628 Thanks
Posted February 08, 2011 - 12:22 PM
Congrats on getting her up and running! She sounds good! Great deal BTW!
#22 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 08, 2011 - 12:37 PM
Alan, I find every time I try to check for spark by looking for it I get shocked so I have since quit looking for the spark and just grab a hold of it to test it. If the shock gets past my elbow I know I have excellent spark. :D
Can't beat the price of the good ole "Arm-O-Meter Spark Tester," and its always within reach when you need it. :D :D :D
#23 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted February 08, 2011 - 12:39 PM
I thought the 68, 69 had points?
:anyone:
I think Tecumseh totally dropped points ignition on the HH series midway 1967.
#24 MH81 OFFLINE
Posted February 08, 2011 - 08:30 PM
Well, the saga continue. Got it all back together, the fuel line fixed, et al... RUNS GREAT. The 2nd time I started it, the switch felt funny, wouldn't turn off, wouldn't let the key out. Hey, it's 40 years old, what did I expect? LOL, this realization still didn't keep me from muttering under my breath.
If anyone knows a good substitute for this switch, I'd appreciate it... Sears only wants $18.98 for sw & shipping (+tx), substitute part. I guess I'll order it tomorrow night, just in case someone knows of a crossref to a Tractor Supply or etc switch.
New #: STD365400 according to Sears, did find THIS on EBAY. Looks like the right one also.
#25 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted February 08, 2011 - 08:33 PM
Well, the saga continue. Got it all back together, the fuel line fixed, et al... then the 2nd time I started it, the switch felt funny, wouldn't turn off, wouldn't let the key out. Hey, it's 40 years old, what did I expect? LOL, this realization still didn't keep me from muttering under my breath.
I think TSC has the indak key cylinders.
#26 Texas Deere and Horse ONLINE
  • 14,796 Thanks
  • 15,495 posts
Posted February 08, 2011 - 08:40 PM
Alan, for $17.56 , I don't think you can go wrong on this switch.
#27 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted February 08, 2011 - 08:59 PM
About ten bucks at O'Reilly Auto Parts for a generic key switch. I put one in one of my Power Kings last year. It was identical to the factory switch in the PK. They have both kinds for mag ignition and battery ignition.
#28 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted February 08, 2011 - 09:24 PM
A generic will not work on these. There is no starter solenoid so all the starter current goes through the switch. If you use a generic with small terminals you have to install a starter solenoid. The replacement should have big terminal lugs on two of the positions, cant remember exactly which two. if you use a generic with small termenials and no solenoid you will burn up the switch or the starter.
#29 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted February 08, 2011 - 09:59 PM
Nice find. Looks like a good deal for the money. Have fun with your new GT.
#30 MH81 OFFLINE
Posted February 16, 2011 - 11:12 PM
Bought a switch thru Ebay since I couldn't find it locally. Pt# on bag is 31-2942. Only difference is the kill & accy posts are push-on instead of screws. No biggie. The two start posts are very heavy copper clad (I think they are even thicker than the originals) and it works great!
There seem to be 2 different switches for GT's with that part #, I did a little looking for it afterwards by the bag # & there is also a John Deere switch that is NOT a substitution. Make sure the one you buy crosses to the original Roper switch # of 365401R.
Got the chains on last night & the 25 lb weights, thought I'd see what it would do with the hardpack & slush in front of the house. All I can say is "Wow" this thing will push. IDK what it'll do with 6" of snow, but it was peeling the stuff off our deadend road & where it couldn't, it was sliding the front end over opposite the plow angle. Really happy to take it for a short workout. It was dark, so no vid, but maybe tomorrow?
