Speedx
17 replies to this topic
#16 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 31, 2014 - 03:27 AM
Ah, yep, and it looks to be cast iron not steel (unless cast steel), i knew something was missing with mines, i think mines had just the rod welded to the beam.
  • Lauber1 said thank you
#17 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted July 31, 2014 - 05:09 PM
seen a lot of pictures with the wheel being rubber, on a small sized rod. But most of them seem to be on the right hand side. I thionk this tractor was taken aprt, and the owner forgot how it went back together.
  • trowel said thank you
#18 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 31, 2014 - 06:01 PM
Ah, makes sense, iron would be pre war, had a look and see it in the pictures too, good eye.
Figured my Speedex at 1951, model 8 Briggs flywheel date, looked like the engine was never removed so i guess it correct, with yours having a Clinton it ventures a thought, i wonder if Speedex switched to Clinton like DB did with Continental at the same time then switch back ?
