Tubeframe Axle Seal Leak....again!
4 replies to this topic
#1 68guns OFFLINE
68guns
  • 124 Thanks
  • 80 posts
Posted July 27, 2014 - 07:29 AM
Hey guys ..I replaced all the oil seals on my G10 back in April and now the left side axle seal is leaking again. Anyone have any ideas why this is happening so soon after new replacement? Just started leaking recently.
#2 Bolens 1000 ONLINE
  • 17290 Thanks
  • 18793 posts
Posted July 27, 2014 - 07:54 AM
If the shaft has any rough spots or burrs that will eat away at the seal.
Did you get a good quality seal? The originals had a heavy duty double lip seal.
I do stock them if needed.
  • Bill56 said thank you
#3 JDBrian OFFLINE
  • 9666 Thanks
  • 14162 posts
Posted July 27, 2014 - 03:20 PM
Not sure what the insides look like on those rear axles but if the bearings are worn it can cause the seals to leak. Likewise if there is a lot of axle end play for some reason.
#4 framesteer OFFLINE
framesteer
  • 530 Thanks
  • 254 posts
Posted July 27, 2014 - 04:58 PM
Be very careful not to damage the seal lips on the shaft threads.  I usually don't have the right diameter seal installer, so I use a rolled up piece of thin (.002" or .oo3") shim stock.  Roll the shim stock on itself to make a cylinder. Make sure there are no exposed sharp edges on the shim stock edges.  Insert the rolled up shim stock into the seal, then carefully allow the shim stock to expand inside the seal until it fits over the threaded portion of the shaft.  Slide the shim stock with seal until the seal itself can be slide onto the smooth diameter of the shaft where the seal normally rides.  The seal should not leak because of installation problems.
  • Bill56 and Kfs35 have said thanks
#5 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6355 Thanks
  • 4417 posts
Posted July 27, 2014 - 06:12 PM
If the seal was not seated completely it could be sitting in there slightly crooked.That will wear a seal out really quick.
