Ford 09Jc3336
10 replies to this topic
#1 Southern Ray OFFLINE
Southern Ray
  • 1 Thanks
  • 2 posts
Posted July 26, 2014 - 09:10 PM
Recently inherited a Ford yard tractor from my father in law.
It has a hydrostatic transmission. I guess a Jacobsen.
I Googled the number and keep getting LGT.
Mine does not have LGT in the nameplate model number.
I want to know what type of oil to put in the transmission.
will plain non detergent 30w do?
It has the in-line filter.  What is the number for this filter?
How much can I pull before I risk burning out the transmission?
thanks,
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,672 Thanks
  • 4,647 posts
Posted July 26, 2014 - 10:17 PM
From the rear it looks like my LGT-145.
#3 lyall OFFLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
First welcome to GTTalk and the forums
do not put in the 30W oil is should be used in the motor
use a hydraulic oil
I am not for sure which type of hydraulic oil ti tell you
I only have gear transaxles
Edited by lyall, July 26, 2014 - 10:18 PM.
#4 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,672 Thanks
  • 4,647 posts
Posted July 26, 2014 - 10:18 PM
See you are in TX, where about? I may be interested if you are planning to sell it.
#5 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,672 Thanks
  • 4,647 posts
Posted July 26, 2014 - 10:21 PM
I use Mystik AW Hydraulic Oil ISO 68, I think I got this from Tractor Supply. The filter is a FRAM PH-16
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,672 Thanks
  • 4,647 posts
Posted July 26, 2014 - 10:23 PM
Sorry, Welcome to GTT, I was following several other posts and saw yours. :worshippy1:
#7 FixItCharlie OFFLINE
FixItCharlie
  • 581 Thanks
  • 366 posts
Posted July 26, 2014 - 10:37 PM
Welcome to the forum. The Fram PH16 is the spin on filter. I do not have the in line filter number right now but can look at the one I removed to tell you what that number is & from something other post in this forum that this part would be available only at New Holland Dealers. I went through the conversion to the spin on filter shown in this post http://gardentractor...s-fluid-change/
Charlie
#8 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted July 27, 2014 - 12:07 AM
from the number you posted I believe it is a LGT 165.from the rear it looks like mine.is it open sided or closed side?
Edited by tinbender7, July 27, 2014 - 12:08 AM.
#9 boyscout862 ONLINE
  • 13,691 Thanks
  • 9,475 posts
Posted July 27, 2014 - 01:34 AM
Welcome to GTT. Please post a few views of the tractor. It may be an even better tractor than a yard tractor. Check the Manuals Section for what you may need. Three free downloads per day are allowed. Good Luck, Rick
#10 KennyP ONLINE
  • 41,474 Thanks
  • 47,403 posts
Posted July 27, 2014 - 05:41 AM
:wave: Welcome to the forum! That model number is for an LGT 165 closed side ('77-83). A good quality Hydraulic/trans oil is what I use.The inline filters are quite expensive, around $100. It would be cheaper to convert to the spin on.
#11 TomLGT195 ONLINE
TomLGT195
  • 4,098 Thanks
  • 2,927 posts
Posted July 27, 2014 - 06:32 AM
:welcometogttalk:  :wewantpics:
Hytrans fluid.like Kenny said. After what i saw yesterday at a tractor pulling contest, quite a lot. Providing its properly maintained.
