Free Is Good, And Bad
4 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted July 26, 2014 - 08:04 PM
hi guys i was given a toro ground master, mid 80s i would think, hydro, 72 inch deck, pretty good shape all over, now the bad, it has a 4 cylinder continental motor, which is seized, the p/o, stopped using it 7 years ago after a govener problem (the engine would suddenly race) , stuffed it in a garage for 5 and 2 years outside under a tarp, i have pulled the plugs and the starter and tried turning the crank with a big screw driver, no go. i am now soaking the cylinders with release all, if all that fails how is it for parts for this motor, thanks
  • boyscout862 and New.Canadian.DB.Owner have said thanks
#2 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 3,951 Thanks
  • 1,865 posts
Posted July 26, 2014 - 08:32 PM
The new parts for the Continental engines are very expensive.
That should be a 327 model and have the Continental R-08 engine.
There are 2 used engines for sale on ebay right now.
http://www.ebay.com/...=item4ad798452f
http://www.ebay.com/...=item2a40ca541e
The good thing is that the engines in Groundsmasters are connected to the hydro transmission by a flex coupling that attaches to the front of the crank shaft.
This makes it fairly easy to put just about any engine that you want into one of these tractors.
Edited by jdcrawler, July 26, 2014 - 08:45 PM.
  • MH81, Cvans, Rock farmer and 1 other said thanks
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 26, 2014 - 09:08 PM
that first ebay links i dealt with that guy for some parts a while back good guy to deal with!! would buy again
  • jdcrawler and farmer john have said thanks
#4 boyscout862 ONLINE
  • 12,832 Thanks
  • 9,160 posts
Posted July 27, 2014 - 01:21 AM
Before giving up, soak it for a couple of weeks. Find out which cylinder has both valves closed(piston near top of the cylinder). An easy way to put alot of force on it wil be to fill the cylinder with engine oil through the spark plug hole. When it is full with no air bubbles, screw in a spark plug to grease gun adapter. This is make from an old spark plug and a zerk fitting. You can drill and thread the zerk fitting into the base of an old plug. Attach a grease gun and pump. The grease gun can cause very high pressure in the cylinder if there are no leaks. This will usually move any piston. Good Luck, Rick
  • sacsr and farmer john have said thanks
#5 Gtractor ONLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
Posted July 27, 2014 - 07:45 AM
25+ years ago when I worked on golf courses across the country I bought one of those for my dad with a blown engine.  It was a 3 cylinder Renault gasser if I remember correctly.  He put a Datsun B-210 [car] 4 cylinder engine in there and there was no mods required to the frame but he did have to move the rear axle back for oil pan clearance.  Then he put on a belt drive governor and it was good to go.  Very simple conversion.
