John Deere 210
7 replies to this topic
#1 cubcadet123 OFFLINE
cubcadet123
  • 5 Thanks
  • 5 posts
Posted July 26, 2014 - 10:33 AM
I have a John deere 210 im fixing for a guy. The transmission is bad. He aaid he shifted it and heard a pop and it wouldnt move. I have the tranny out and up on its side with the left wheel bolted on. I pulled the drive pulley off and on the hub i took out aittle allen head set screw. To me it looks like the hub is threaded but i could be wrong. Im trying to pull it apart without pieces flying everywhere. Im ndw to the john deeres since im a cub cadet guy. Thanks
  • superspeedex said thank you
#2 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,433 posts
Posted July 26, 2014 - 12:02 PM
Welcome to GTT. I do not have an answer for you but someone will be along to help. Good Luck, Rick
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 26, 2014 - 01:30 PM
Hi cucadet123
Soak it in pb blaster or heat it up and put a puller on it chances are it rusted on all of mine are
Looks to me like theres just a set screw
http://www.ebay.com/...=item35d93f0349
page 17 in this manual
http://gardentractor...-drive-systems/
my rebuild
http://gardentractor...ild#entry435726
#4 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,809 Thanks
  • 4,304 posts
Posted July 26, 2014 - 02:28 PM
yep, welcome to GTT
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 26, 2014 - 02:53 PM
If you are ever looking for parts diagrams for John Deere tractors you can access them at jdparts.com. You do a model no. search and pick your equipment out of the list that comes up. Those hubs can be a monster to remove.
#6 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted July 26, 2014 - 08:42 PM
you need to remove the c-clip on the axle that holds the wheel hub on the axle
#7 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 26, 2014 - 08:47 PM
I think hes talking about the output shaft hub the holds the drive pulley on
  • lyall said thank you
#8 lyall ONLINE
lyall
  • 2,227 Thanks
  • 1,593 posts
Posted July 26, 2014 - 10:26 PM
you should have to remove the drive pulley hub unless the seal is bad
you can download the manual the transaxle in the manual section
it will help a lot
while you have it apart also check the shifting folks
there are little balls and spring for the shifting folks and that go bad and cause it to go into two gear at the same time
if the springs are bad I know the you can get them from Deere.  last year I checked and Deere had around 2000 of them
