Hyd Oil Filter
6 replies to this topic
#1 Pirate OFFLINE
Pirate
  • 2 posts
Posted July 26, 2014 - 09:10 AM
Do I have to drain the hyd oil just to remove the filter? I have a 3014 Ingersoll. There seems to be a leak at the hose connection behind the filter.
#2 JDBrian OFFLINE
  • 9,593 Thanks
Posted July 26, 2014 - 02:42 PM
Welcome to GTTalk. I'm not familiar with the Ingersol tractors. There are folks on here who will know th answer to your question. Until then, have a look at our manuals section. There may be a service manual that will give you the info. you need.
  • Pirate said thank you
#3 gopher OFFLINE
gopher
  • 612 Thanks
  • 671 posts
Posted July 26, 2014 - 04:58 PM
As JDBrian said you will find the manual you want as the 3000-4000 series operator's manual. If it's even close to the 500hr mark if your taking off the filter any way I'd go ahead and change it. Remember it uses high quality MOTOR OIL. I-m sure others will chime in to let you know what works for them.
#4 TomLGT195 OFFLINE
TomLGT195
  • 3,017 Thanks
  • 2,344 posts
Posted July 26, 2014 - 07:40 PM
Just here to say Welcome to GT Talk! Hang around , there's a great bunch of guys with a wealth of helpful info. Tom
#5 boyscout862 ONLINE
  • 10,502 Thanks
  • 7,926 posts
Posted July 27, 2014 - 01:09 AM
Welcome to GTT. Relax and enjoy the site. Good Luck, Rick
#6 Pirate OFFLINE
Pirate
  • 2 posts
Posted July 27, 2014 - 11:04 AM
I found the source of the leak. The oil filter rubs on a hyd fitting...bad design...I will put a rubber barrier next to the new filter to avoid another future mess. Thanx for your interest.
#7 olcowhand ONLINE
  • 36,868 Thanks
  • 30,148 posts
Posted July 27, 2014 - 11:06 AM
Shell Rotella 15W40 is about the best oil to use.
