New Mystery Machine....
27 replies to this topic
#16 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 25, 2014 - 05:59 AM
I wonder if someone was running it or at least working on it recently. That muffler looks newish!
#17 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 25, 2014 - 06:41 AM
The man who gave it to me told me it was his better halves fathers. It hasn't ran in years. He had a can over the exhaust that rotted off. The muffler is newer he said. It's sitting on the big work trailer, so when I get in, after I move the beast to the back, I'll snap photos & post.
  • Cvans said thank you
#18 jabelman OFFLINE
jabelman
  • 2,216 Thanks
  • 1,589 posts
Posted July 25, 2014 - 09:53 AM
Now you have to find a plane to tow around your yard
#19 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 25, 2014 - 06:24 PM
I hope this isn't the beginning of the farm tractor addiction! The more I look this over, the more I like it. Engine doesn't turn over, not surprised there. The rear end, the wheels when jacked up, spin in opposite directions. I am only able to shift in third too. One tire holds air in the front, the other apparently had a tube that burst out of the sidewall and blew out with a rather large bang earlier.
S# VAIW493439 something.
More photos soon.
With the wheels up, brakes work, clutch I don't know if it does.
I should be able to shift in all gears with the engine not running. But with the engine seized, would that prevent me from shifting into other gears?
#20 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted July 25, 2014 - 06:47 PM
It shouldn't, you should be able to move it around. How many gears is it supposed to have?
#21 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 25, 2014 - 08:07 PM
5 I think and R. Will confirm tomorrow. What would prevent me from shifting then?
#22 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted July 26, 2014 - 06:42 AM
Try rocking the driveshaft a little to the left/right line up the gears, sincro might be stuck.
#23 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 27, 2014 - 06:57 PM
Had a minute to tinker, engine turned over with a big wrench! I did notice that the clutch bell housing has alot of dirt in it! Each time I turned the engine over, dirt came out.
With my friend, we turned it over multiple times, and he got a mountain of dirt out. Going to try to vacuum and air blast the rest out.
And, 3rd gear works!
Better than an hour ago!
  • olcowhand said thank you
#24 olcowhand ONLINE
  • 41,035 Thanks
  • 31,384 posts
Posted July 27, 2014 - 07:01 PM
I've had old engines locked from crap around the flywheel, both small air cooled, and larger engines like yours in this case.  Likely all that was holding it.
#25 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted July 27, 2014 - 07:07 PM
I sure hope so :)
I do need a tire though, would like two.
Currently has an Armstrong
industrial all purpose 6.90-9
on it, where could I find a used one or two to replace these with?
#26 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,998 posts
Posted July 27, 2014 - 07:15 PM
I only found two types of those size, ribbed trailer tires and industrial forklift tires. The forklift tires I found were Carlisle and Deestones. Miller Tire has them.
#27 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 9,846 Thanks
  • 5,946 posts
Posted August 16, 2014 - 08:40 PM
Any more pictures of this?
#28 OldBuzzard ONLINE
OldBuzzard
  • 7,018 Thanks
  • 4,790 posts
Posted August 17, 2014 - 04:17 AM
Since I got up at 0400 and it was too early to do much of anything else, I did a bit of Googling on the VAIW.
I found more than one source that claims that there were a total of 3,793 built.
Here are a couple of links with some additional info:
http://www.tractorda...-case-vaiw.html
http://books.google.... manual&f=false
It seems that not all of them were sold to the military.
In all the pics I found I saw nothing like the front end on yours.
I'm going to speculate that it was done by a previous owner for a specific purpose.
In any event, it's definitely an interesting tractor, and well worth restoring.
